http://auszookers.com/forum/
PLEASE SHOW ME!!!
http://auszookers.com/forum/viewtopic.php?f=37&t=50638
Author:  ZookiBoi [ Tue Jul 28, 2015 9:09 am ]
Post subject:  PLEASE SHOW ME!!!
Can someone, ANYONE, show me an image clearly outlining where the F&CK the warm idle screw is on the carby of a G13ba engine from a 1991 suzuki JX sierra. PLEASE.
Thank you
Author:  ZookiBoi [ Tue Jul 28, 2015 9:11 am ]
Post subject:  Re: PLEASE SHOW ME!!!
Is it this screw on the far left of the image??
Author:  jdk81 [ Tue Jul 28, 2015 9:48 am ]
Its the long screw, just below the numbers 1 and 3.
The screw far left is the fast idle (1500-2500 rpm at less than 25 degrees C water temp)
Author:  ZookiBoi [ Tue Jul 28, 2015 9:56 am ]
Thank you very much. Ok I think then there must be some vacuum leak because I can screw that screw all the way in and out and nothing changes.
Author:  jdk81 [ Tue Jul 28, 2015 10:27 am ]
It can be a problem with the choke
incorrect fast idle setting
vacuum leak
a problem with the links (if someone has fiddled with the carby recently)
timing/vac advance
vacuum hoses incorrectly connected
download a FSM
http://www.suzukiinfo.com/sierra/suzuki ... 413fsm.pdf
Author:  ZookiBoi [ Tue Jul 28, 2015 10:51 am ]
Thanks mate. I will keep playing with those things listed and see what happens. Cheers again.
