| Jimny front radius arms http://auszookers.com/forum/viewtopic.php?f=37&t=50711 |
| Author: | sur5a [ Tue Aug 04, 2015 3:40 pm ] |
| Post subject: | Jimny front radius arms |
Ive got stock radius arms with jimnybits castor correction bushs in the front,one of the arms is fairly bent. Im thinking of replacing the arms with corrected ones ,I'm running a 50mm trail master lift with front diesel springs.No swaybar My question is ,what are the negatives,if any,of running 3 inch lift corrected arms on a 50 mm set up ? |
| Author: | sur5a [ Tue Aug 18, 2015 7:23 pm ] |
| Post subject: | Re: Jimny front radius arms |
Anyone ? |
| Author: | monley [ Tue Aug 18, 2015 7:59 pm ] |
The steering will feel heavier if you had castor angle corrected arms to suit a 3" lift on a 2", but if my memory serves me right the castor angle would still be with-in factory spec. How bent is the arm? |
| Author: | sur5a [ Tue Aug 18, 2015 8:06 pm ] |
Cheers monley,its got a fairl size bend in the middle,suspension place said bin it |
| Author: | Jezza86 [ Wed Aug 19, 2015 8:01 am ] |
would be cheaper to get seconf hand arms and press the bushes in. the JB ones are welded with from what i have read is a nono with the ADR's or something eiter way i ran them and i rate them with stock jimny rubber bushes. |
| Author: | sur5a [ Wed Aug 19, 2015 9:25 am ] |
Thanks Jezza,not sure at this stage which way ill go |
| Author: | got_bar_work [ Wed Aug 19, 2015 12:52 pm ] |
U can get welded arms passed they just need to be crack tested |
