It is currently Thu Aug 06, 2026 2:12 pm
Vehicle: 2013 JImny
Post Posted: Tue Aug 04, 2015 3:40 pm
Ive got stock radius arms with jimnybits castor correction bushs in the front,one of the arms is fairly bent.
Im thinking of replacing the arms with corrected ones ,I'm running a 50mm trail master lift with front diesel springs.No swaybar
My question is ,what are the negatives,if any,of running 3 inch lift corrected arms on a 50 mm set up ?
Vehicle: 2013 JImny
Post Posted: Tue Aug 18, 2015 7:23 pm
Anyone ?
Post Posted: Tue Aug 18, 2015 7:59 pm
The steering will feel heavier if you had castor angle corrected arms to suit a 3" lift on a 2", but if my memory serves me right the castor angle would still be with-in factory spec.
How bent is the arm?
Vehicle: 2013 JImny
Post Posted: Tue Aug 18, 2015 8:06 pm
Cheers monley,its got a fairl size bend in the middle,suspension place said bin it
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Wed Aug 19, 2015 8:01 am
would be cheaper to get seconf hand arms and press the bushes in.
the JB ones are welded with from what i have read is a nono with the ADR's or something
eiter way i ran them and i rate them with stock jimny rubber bushes.
Vehicle: 2013 JImny
Post Posted: Wed Aug 19, 2015 9:25 am
Thanks Jezza,not sure at this stage which way ill go
Post Posted: Wed Aug 19, 2015 12:52 pm
U can get welded arms passed they just need to be crack tested
Users browsing this forum: No registered users and 81 guests
