It is currently Sun Sep 27, 2026 6:12 pm
Vehicle: 2006 2.7 prestige auto.
Post Posted: Tue Sep 08, 2015 9:34 pm
Hi all
I installed a dobinsons 40mm lift to my NGV over the weekend and it looks like I made a small error. When I put the rear spring in the rh side I didn't seat the bottom of the spring in the keeper properly. It's about 180 degrees out and the spring sits a bit high. And now the spring sits with a nice curve in it. I have jacked up the car and tried to turn the spring a few different ways but only got about an inch of rotation out of it . The guy who did my alignment didn't notice it either and I don't really want to drop the shock and have to do another alignment on it if I can avoid it.
Apart from buying a set of spring compressors is there another way to rotate the springs in the keepers ?
Thanks
Marc
Post Posted: Tue Sep 08, 2015 10:52 pm
The probability is you're going to need to re-do the alignment anyway - you're going to lower that corner of the car by something in the region of 13mm - which will in turn raise the diagonally opposite corner of the car by roughly the same amount, change the front ride height of a macpherson strut IFS and the caster & camber will also change.
Post Posted: Wed Sep 09, 2015 8:09 pm
Thanks for that I will just book it in for an alingment and get them to rotate the spring also.
Users browsing this forum: No registered users and 25 guests
