Joined: Mon Oct 25, 2010 12:13 pm Posts: 1334 Location: WeSt RaDeLaIdE
Vehicle: Suzukiless these days..
Posted: Tue Sep 08, 2015 10:55 pm
Hi smart ones.
Currently building a camping style trailer, Have a CTEK charging my second/aux battery that I run a fridge and two lights and a couple of sub point off...
Is there any reason I can't hook up a couple of correct gauge wires to the battery being charged by the CTEK And run them via an Anderson plug to my trailer to also charge a smaller AGM battery?
Assumption #1 battery #2 is on the vehicle and battery #3 is on the trailer. Assumption #2 battery #2 and battery #3 are both AGM.
Rule #1 - batteries should NEVER be paralleled unless they are of the same chemistry, capacity & age.
When you break rule #1, the end result is reduced battery life - I'm not going to go into all the permutations & combinations, but I will say that different chemistries require different charge voltages (bulk charge & float charge) and you'll end up overcharging one and undercharging the other - a very similar thing happens when the ages & capacities are different, but in these cases the impact is greater on the discharge side of the equation, and the batteries will quite rapidly "equalize" themselves, and I use the term "equalize" in a layman's sense (it does have a very specific meaning when discussing batteries & charging) - the batteries will soon behave as if they are as small as the smaller capacity and as old as the older battery.
In addition voltage drop across the cables & connectors (and yes, I did note that you stated "correct gauge wires") will cause the charge voltage at battery #3 to be lower than it is at battery #2, which will most likely result in undercharging - the CTEK will see battery #2, and adjust accordingly - in theory, you might "luck out" and because it's a smaller battery, it does charge reasonably well, but in reality how much charge it needs will be dictated by how much it has been discharged.
You could manually switch between them. Split the circuits after the d250s. A 3 way battery isolator for 40 bucks will sort it out or for a few more bucks you could do it electronically but in the end a manual process. I'd do this and solar so you have charging choices. Or just get a cheeper DC to DC charger for your camper.
Users browsing this forum: Google [Bot] and 121 guests
