It is currently Tue Sep 22, 2026 7:40 am
Vehicle: 92 lwb vit
Post Posted: Sat Oct 17, 2015 6:55 am
Hi got a 92 lwb vit. Keep hearing stories on here that the ally cased ones are no good and will let you down. Is it just the ally case you change to steel or the whole diff? Im pretty useless with cars. I want to make mine bulletproof for some big touring.
Is it a case of the ally ones are no good because they are weak?
Can a bash plate fix this?
Or does it break just because of the internal stress?
Is it just a case of getting a gv steel outer and swapping the insides over? Are there any threads on this? Tried typing it in but i just get confused haha.
Please keep responses in lamens terms thanks :)
Any info on what i will need to make this swap happen will be much appreciated. Cheers
Post Posted: Sat Oct 17, 2015 7:37 am
Internal stress kills alloy casing.
All internal bits are steel.
Yes put your internals into GV steel front diff casing (which includes axle housing).
Bash plate is wise anyway, to protect cross member from damage.
Vehicle: 92 lwb vit
Post Posted: Sat Oct 17, 2015 8:52 am
Cheers Chris. So I am just after any year gv front diff housing? Bolts straight in?
Post Posted: Sat Oct 17, 2015 8:59 am
viewtopic.php?f=17&t=6953
Lots of good info in above post.
Must be a manual, must have the same looking diff,
must include matching mount as later ones were different, not sure on year range.
My steelie came from a 98
Vehicle: zook
Post Posted: Sat Oct 17, 2015 10:26 am
I happen to have one sitting right here that I could be persuaded to part with. Just sent you a PM.
Vehicle: 92 lwb vit
Post Posted: Sat Oct 17, 2015 10:33 am
Cheers for the good info. I have an auto, will that bugger it up?
Post Posted: Sat Oct 17, 2015 11:56 am
Mine is an auto. I mean the steel diff is only found on manual GV's
Vehicle: 92 lwb vit
Post Posted: Sat Oct 17, 2015 2:02 pm
sweet. sounds like im grabbing watermouses.
Post Posted: Thu Oct 22, 2015 12:57 am
If you don't I have an airlocked, bushed, 5.12 that I'm pulling out of my car. Buzz me if the above falls through.
Vehicle: Vitara 1.6
Post Posted: Thu Oct 22, 2015 11:38 am
I could be interested in that. Now i hav a solid vitara to start on its on my list. After body lift and was looking forward to doing the diff work myself so depends on what you want for it.
Sent from my SM-G900I using Tapatalk
Users browsing this forum: Google [Bot] and 57 guests
