It is currently Mon Sep 21, 2026 1:23 am
Vehicle: 1984 holden drover (lwb zook)
Post Posted: Wed Oct 21, 2015 7:38 pm
HEY
Guys i have read about 6 posts on Protec olive drab or green camouflage paint but none seem to have what im looking for, im just wondering if you need thinners with this paint or is it just buy, whack in a gun and paint?
ill be doing a closed door job and painting all hinges and stuff the camo black. for the black ill just use a spray can but with the cab (LWB Ute) ill be using a compressor and gun. any idea on how many liters i would need roughly?
Any help would be great
Sam
Post Posted: Thu Oct 22, 2015 1:58 am
Thinners if you're spraying it. IIRC instructions are on the can, if not google protec 342 and there's a pdf with all sorts of info.
FWIW a friend of mine said he used about 2l to paint his trayback defender cab. A 4l can is only $55 so I'd just grab one of those.
Vehicle: MG410 Gypsy
Post Posted: Thu Oct 22, 2015 8:45 am
Im with sideways, the paint is cheap enough, i painted a SWB and a UTe with one 5ltr tin.
definately needs to be thinned.
Post Posted: Thu Oct 22, 2015 9:09 am
alright sweet ill grab a 4ltr one today, do protec sell the thinner that is appropriate for it?
I read somewhere that if you use certain thinners it can mess up because it dosent go well with the paint already on the car?
Post Posted: Thu Oct 22, 2015 9:15 am
they should, i just bought mine from supercheap.
Post Posted: Thu Oct 22, 2015 9:24 am
i work at super cheap on weekends so get great discount, what thinners did you get? the general purpose? or the enamel one?
do you have any photos of your car and how it came out?
Vehicle: Mighty Boy / LJ81 Hybrid
Post Posted: Thu Oct 22, 2015 9:50 am
....Yet still get info from an online forum. When you leave Supercheap you'll be able to go straight to Bunnings Technical Department.
Post Posted: Thu Oct 22, 2015 9:53 am
enamel thinners.
Check my build thread. Sierra Sj51t ute - Blink
Post Posted: Thu Oct 22, 2015 10:03 am
I only work on weekends for spare cash and 80% of the time do stock, even so with parts im perfectly good just not 100% confident with paint
yeah checked your build looks sweet
thanks
Post Posted: Thu Oct 22, 2015 10:24 am
Good luck and dont stress, the protec range of 342 paint is easy stuff to paint with. Sticks on anything, just dont lay it on too thick.
Post Posted: Thu Oct 22, 2015 6:55 pm
so bought it all and checked out the internet to see mixing quantity's because there is nothing on the existing tins that i bought at it recons use a primer or is this not needed?
and im not sure what kind of ratio i use of thinners to paint as it just says 100 parts paint and up to 15% reducer.
here is the link to have a look.
http://www.ppglic.com.au/uploads/tds/34 ... 202011.pdf
Post Posted: Thu Oct 22, 2015 11:04 pm
call the paint company they should be able too help you with the mixing ratios.
Post Posted: Fri Oct 23, 2015 9:52 am
or you can check the multiple threads, i cant remember what mix ratio i used.
You wont need to mix in a primer.
Post Posted: Mon Oct 26, 2015 7:12 pm
This paint is so simple to use its not funny. no need to over think it. I used a 4L tin to paint my SWB. Preparation because the paint was ok was just rough up the old paint iwht a scotch pad. It's enamel, it'll stick to almost anything. Thin paint 10-15% with turps and spray on.
Post Posted: Mon Oct 26, 2015 9:37 pm
this. if you have a litre add 100-150ml thinners/turps and go for it.
Users browsing this forum: No registered users and 62 guests
