It is currently Thu Sep 24, 2026 12:31 pm
Vehicle: Suzuki Jimny Sierra
Post Posted: Tue Nov 03, 2015 4:23 pm
2015 Jimny comes with Vehicle Stability Control /Electronic Stability Program.
I'm wondering if it's compatible with diff locks (ARB Air Locker, or Eaton Elocker or other types of diff locks).
Will shifting into 4H/4L disabling the VSC/ESP?
Vehicle: '15 Jimny MY15
Post Posted: Mon Nov 16, 2015 3:47 pm
I don't know about the compatibility but it does disable when you shift into 4L.
Post Posted: Mon Nov 16, 2015 5:00 pm
it will just work with the brakes like all other traction control.
will be fine if it doesn't work in lowrange,
PS eaton don't make a locker for a jimny
Vehicle: SJ80, SE416
Post Posted: Mon Nov 16, 2015 6:43 pm
Why would having a locked diff have any negative effect on ESP except for disabling it? The wheel speed sensors will all be inputting the exact same speed into the computer making it think everything is ok... unless you want the ESP to be sensing and doing something which it can't anyway if the wheels are locked together.
Post Posted: Tue Nov 17, 2015 8:01 am
basically it will be an issue if the esp started trying to work if the diff was locked.
I cant imagine it ever would but you never know with these kooky computers working everything
Post Posted: Tue Nov 17, 2015 8:19 pm
Does the Jimmy ESC use steering angle and g sensor inputs?
Users browsing this forum: No registered users and 47 guests
