Page 1 of 1
[ 6 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
Bulldog 61
Vehicle: SJ70 Tintop, SJ51T, 97 Coily
 Posted: Mon Dec 07, 2015 7:45 am |
Is there any difference in the strength of the two transfers? I was going to fit the NT switched case in my LWB and someone has told me they are heaps weaker then the WT cases.....T or F
Vehicle is a Holden Drover Trayback 1.3 motor and 5 speed and I have been told its a WT transfer with the drum handbrake fitted to it in the LWB utes.
4x4xzook
Joined: Wed May 16, 2012 8:41 am Posts: 730 Location: Melbourne
Vehicle: MG410 Gypsy
 Posted: Mon Dec 07, 2015 7:58 am |
i dont think there is a difference, aslong as they are both 1.3 cases all should be the same.
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13007 Location: Melbourne
 Posted: Mon Dec 07, 2015 8:47 am |
As per 4x4xzook - there is no difference in strength (internally*) between the NT and WT cases - all parts are interchangeable.
You won't be able to tell if it's a WT or NT transfer if it's had a drum fitted -they're the same.
*Here's the caveat though.
NT sierras use a smaller flange bolt pattern on the yokes and smaller bolts. (8mm) VS WT, Coil and Vitara which use a larger pattern and 10mm bolts. I have heard of people having trouble keeping the NT yokes tight on larger tyred/geared cars. That's the only difference between NT and WT functionally. However, there are no transfer drum brakes with the WT pattern, so that's not an option for you. Additionally, there's little advantage having the large bolt pattern at transfer case and the small pattern at the diffs, so it's a moot point.
Bulldog 61
 Posted: Mon Dec 07, 2015 3:09 pm |
Thanks Guys, I didnt think one version was stronger than another.
Gwagonsteve are you saying as I currently have the transfer brake on the Transfer Case in my vehicle it is a NT version transfer case?
Gwagensteve
 Posted: Tue Dec 08, 2015 9:41 am |
Effectively yes- as the flange patterns and drum are the only difference between wt and nt if you have a drum and 8mm flange bolts you have a nt case.
Bulldog 61
 Posted: Thu Dec 10, 2015 1:53 pm |
cool got it...... thanks heaps
Page 1 of 1
[ 6 posts ] |
Users browsing this forum: No registered users and 97 guests
