It is currently Thu Aug 06, 2026 9:33 am
Vehicle: 97 maruti ute
Post Posted: Mon Dec 07, 2015 2:46 pm
Hi, I've got a 97 stockman I've been working on over the past 12 months, and have run into a small issue..
The issue being the f10a under the bonnet. The lack of power is really starting to get to me
So I was looking around, and a 4agze is within my budget for a power upgrade, but would I be able to get it engineered and legal in qld?
I was also looking at a gti engine swap, but the engines are a similar price up here, and if I could, I'd prefer the extra power, since I want to move up to 33s etc
And what gboxes would be a good fit?
I've heard the t50s are too long?
Any input would be greatly appreciated people
Post Posted: Mon Dec 07, 2015 2:50 pm
I believe the GZE can be legally fitted it QLD.
No, there basically isn't a suitable gearbox. The Toyota 5speeds are too long and the three speed Corolla auto won't take the power.
Personally, I would not go with an engine of this weight or torque- you will find the driveline won't like the power and you'll be on a slippery slope of upgrades/ rebuilding to make it reliable.
Tyre size has little to do with engine power. Tyre size is a gearing issue.
Post Posted: Mon Dec 07, 2015 3:09 pm
Cheers for the info, given me a few things to consider
Outta curiosity, how have people gotten the 4a engine into sierras?
Just shortened and lengthened shafts, and put up with vibration etc?
Vehicle: '96 LWB trayback
Post Posted: Mon Dec 07, 2015 4:37 pm
Shorten the jackshaft and deal with reduced uni-joint lifespan and poor shifter location.
Post Posted: Tue Dec 08, 2015 12:30 am
I didn't consider the shifter being moved back..
Cheers for the info. I'm thinking the gti engine will end up being a lot less headaches
Post Posted: Tue Dec 08, 2015 6:09 am
Yes but then you'll have the power in the wrong place for an offroad car.
G16b for the win.
Post Posted: Tue Dec 08, 2015 8:45 am
+2 for g16b. 4agze's seem to be becoming popular again, I dont know why. Wheeling is the only motor sport you spend money on to go slower. You want torque and reliability.
Save the cash from the hassle of the 4agze, put a g16b in and buy some reduction gears. Will be everything you need.
Post Posted: Tue Dec 08, 2015 9:21 am
gti and the 4a swap are just about the crappest two engine swaps I can think of.
g16 is heaps. but if you want more look at the J20a motor.
Post Posted: Tue Dec 08, 2015 6:40 pm
So apart from the torque issue, what's the big downsides to the gti swap?
I figured it would work better for me since I rally alot. Most of the tracks I run are really good for it. I've got one track at the back of my house is like a 20km uphill wrc stage
And otherwise I'm mainly doing hill climbs etc, not a lot of rock crawling up this way
Vehicle: Which one?
Post Posted: Tue Dec 08, 2015 6:42 pm
In that case, the gti swap would probably be fun. A small-tyred sierra with a gti engine that makes all of its power at the top end would be tonnes of fun on that sort of terrain.
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Tue Dec 08, 2015 7:42 pm
Fuck the gti go a 13b turbo.
Post Posted: Tue Dec 08, 2015 11:23 pm
Yeah nah, I couldn't afford to fuel a rotary... Be fun tho
I'm not 100% yet, but definitely leaning towards the gti motor.
Fairly cheap, fairly easy to fit, seems to be boost friendly..
And should have enough power to spin 33s on the highway to get to some of the more challenging tracks...
Post Posted: Tue Dec 08, 2015 11:58 pm
G16b is all of the above and more.
A stock 1.0litre has enough power to drive 33s on the highway - provided you've corrected the gearing to suit the larger tyres.
Don't attempt to substitute power for incorrect gearing as it is a solution that never works.
Post Posted: Wed Dec 09, 2015 1:42 am
Yeah I definitely agree. Gearing is the next big upgrade for me, after the engine conversion.
I'm guessing the main thing I'm wanting is the extra power for overtaking, not having to drop gears all the time going up hills etc
My mates hilux used to drive me insane, it was decent off road, but an absolute pig on any incline
Wait up, a g16 is boost friendly?
The research I've done seems to suggest that's not the case... Any input you could give me on that would be greatly appreciated
Vehicle: Vitara 1.6
Post Posted: Wed Dec 09, 2015 4:05 am
You r3minded m3 of something. Somewhere at home i hav an old Zoom mag where was a rally driver with a vitara. Made a turbo engine out of all factory parts. He used an na crank with the gti head as it gave him a lower compression for the turbo. Would be about 1995 zoom.
Sent from my SM-G900I using Tapatalk
Post Posted: Wed Dec 09, 2015 9:26 am
"Overtaking without dropping gears" - that's torque. A g16b makes almost 30% more torque than a g13B. A g13b has such a high power and torque band that you're definitely going to be dropping gears to overtake because you need to get the revs up.
If you're "rallying around" and driving on road look at a Vitara. Much more stable and potentially handle much better with a much lower centre of gravity.
Post Posted: Wed Dec 09, 2015 1:58 pm
Yeah but I already have a stockman. And I do 4by a fair bit, its just not the only thing I'll be doing.. And having a trayback is quite handy, considering how far I live out of town
But yeah, you guys have given me a lot to think about. I'll definitely look into the g16 a bit more, definitely seems the more sensible solution
Post Posted: Mon Dec 28, 2015 11:36 am
Well, I searched for both engines for weeks, and have found a g13b for 1500, so g13b it is
Cheers for the help people
Users browsing this forum: No registered users and 20 guests
