It is currently Thu Aug 06, 2026 2:18 am
Vehicle: 1997 2ltr V6 Suzuki vitara
Post Posted: Mon Dec 14, 2015 7:58 am
Can anyone help me with finding an 2ltr v6 vitara gearbox, wether it be a car being wrecked or a rebuild kit, must have syncro rings
or what gearbox's are compatible with the H20A engine? Thanks
Vehicle: zook
Post Posted: Mon Dec 14, 2015 1:35 pm
What are the problems/symptoms of the box that you have?
Post Posted: Tue Dec 15, 2015 5:52 pm
http://www.auszookers.com/forum/viewforum.php?f=8
Pop a wanted ad here ^ someone might have one but may not look in the noob section
Hope you find it
Post Posted: Tue Dec 15, 2015 6:57 pm
Syncro rings are buggered 2nd and 5th gear
Post Posted: Tue Dec 15, 2015 8:09 pm
5th synchro? Normally 2nd and 3rd go first
Vehicle: zook
Post Posted: Tue Dec 15, 2015 8:56 pm
Plenty of syncro ring kits on ebay. Would you overhaul it?
Post Posted: Wed Dec 16, 2015 7:30 pm
I would but I can't find the syncro kit for my car only the 4 cylinder models, Suzuki quoted about $110 for a single genuine syncro
Vehicle: zook
Post Posted: Wed Dec 16, 2015 8:57 pm
Can you list your gear ratios and take a photo of the gearbox as best you can?
I believe that the box is the same as the one behind the j20a which is also very similar to the 1.6 albeit with a different 5th gear ratio.
Vehicle: SJ80, SE416
Post Posted: Sat Dec 19, 2015 6:04 pm
Very interesting. Is 5th higher or lower than the 5th in the 1.6 box?
Post Posted: Sun Dec 20, 2015 10:21 pm
Yeah I'll find out and take some photos,
I've heard the j20a is similar, they run the same clutch kit and everything so I'd assume they wouldn't be much different
Post Posted: Mon Dec 21, 2015 10:12 am
input shafts lengths are different on SV420 & SV620's
Vehicle: zook
Post Posted: Mon Dec 21, 2015 4:24 pm
1.6, G16B, manual, 5th gear is 0.86
2.0, J20a, manual 5th gear is 0.795
2.0, H20A manual 5th gear is ?
X2 on the input shaft lengths although the spline is likely to be the same count. (Jimny g13BB and GV j20a had the same spline but different pilot shaft diameter.)
Users browsing this forum: No registered users and 116 guests
