| 1997 2.0ltr V6 vitara gearbox/gearbox rebuild http://auszookers.com/forum/viewtopic.php?f=37&t=51543 |
| Author: | Tommymann [ Mon Dec 14, 2015 7:58 am ] |
| Post subject: | 1997 2.0ltr V6 vitara gearbox/gearbox rebuild |
Can anyone help me with finding an 2ltr v6 vitara gearbox, wether it be a car being wrecked or a rebuild kit, must have syncro rings or what gearbox's are compatible with the H20A engine? Thanks |
| Author: | watermouse [ Mon Dec 14, 2015 1:35 pm ] |
| Post subject: | Re: 1997 2.0ltr V6 vitara gearbox/gearbox rebuild |
What are the problems/symptoms of the box that you have? |
| Author: | bumstein [ Tue Dec 15, 2015 5:52 pm ] |
http://www.auszookers.com/forum/viewforum.php?f=8 Pop a wanted ad here ^ someone might have one but may not look in the noob section Hope you find it |
| Author: | Tommymann [ Tue Dec 15, 2015 6:57 pm ] |
Syncro rings are buggered 2nd and 5th gear |
| Author: | Scrawny [ Tue Dec 15, 2015 8:09 pm ] |
5th synchro? Normally 2nd and 3rd go first |
| Author: | watermouse [ Tue Dec 15, 2015 8:56 pm ] |
Plenty of syncro ring kits on ebay. Would you overhaul it? |
| Author: | Tommymann [ Wed Dec 16, 2015 7:30 pm ] |
I would but I can't find the syncro kit for my car only the 4 cylinder models, Suzuki quoted about $110 for a single genuine syncro |
| Author: | watermouse [ Wed Dec 16, 2015 8:57 pm ] |
Can you list your gear ratios and take a photo of the gearbox as best you can? I believe that the box is the same as the one behind the j20a which is also very similar to the 1.6 albeit with a different 5th gear ratio. |
| Author: | Reubs [ Sat Dec 19, 2015 6:04 pm ] |
watermouse wrote: which is also very similar to the 1.6 albeit with a different 5th gear ratio. Very interesting. Is 5th higher or lower than the 5th in the 1.6 box? |
| Author: | Tommymann [ Sun Dec 20, 2015 10:21 pm ] |
Yeah I'll find out and take some photos, I've heard the j20a is similar, they run the same clutch kit and everything so I'd assume they wouldn't be much different |
| Author: | atari4x4 [ Mon Dec 21, 2015 10:12 am ] |
input shafts lengths are different on SV420 & SV620's |
| Author: | watermouse [ Mon Dec 21, 2015 4:24 pm ] |
1.6, G16B, manual, 5th gear is 0.86 2.0, J20a, manual 5th gear is 0.795 2.0, H20A manual 5th gear is ? X2 on the input shaft lengths although the spline is likely to be the same count. (Jimny g13BB and GV j20a had the same spline but different pilot shaft diameter.) |
