It is currently Fri Jul 31, 2026 12:20 pm
Vehicle: Suzuki Vitara SWB 1992
Post Posted: Thu Dec 24, 2015 10:30 am
Hi there, I have a Vitara 92 manual 5 speed and the shifter has a extreme amount of slop in it (almost like it is in neutral when in gear) I have heard about people replacing 2 bushings that apparently fixes it ? any help would be greatly appreciated, if the bushings is all I need to fix this where can I get them ? and where can I get the lower shifter boots for the gearbox and transfer case ?
Cheers Brian.
Post Posted: Thu Dec 24, 2015 11:36 am
Cheers Brian.
Myron at http://www.zuksoffroad.com/ has a brass shifter bushing (it is called a "G-string" and does not appear in the online catalog right now - call for availability) for the Mk 1 Vitara/Sidekick 5-speed transmission. Also available is a brass version of the plastic "biscuit" ( http://www.zuksoffroad.com/Biscuit-5-speed-trans-remote-bal-tip-bushing_p_1591.html ) that fits on the end of the shifter. Both lasts forever, is inexpensive and costs nearly nothing to ship!
I hope that this helps!
-Ack
http://www.acksfaq.com
88, 88.5 SJ413
Post Posted: Thu Dec 24, 2015 6:06 pm
Thanks AckerDackerly, not only a replacement but a upgrade, I like it :)
Post Posted: Fri Dec 25, 2015 5:37 am
Have you checked that the spring isn't broken?
Vehicle: Suzuki Grand Vitara
Post Posted: Fri Dec 25, 2015 10:13 am
http://www.suzistore.com.au/four-wheel- ... etail.html
Post Posted: Fri Dec 25, 2015 11:52 am
Check that the two slots on the ball havent floged out. I had to weld the slots up and grind new ones on mine. The stick was twisting side to side
Post Posted: Sat Dec 26, 2015 12:36 pm
At the same time, replace the bolt that centres the lever, and replace the transfer lever bush.
bye
Vehicle: Suzuki Jimny Sierra 2015
Post Posted: Sat Dec 26, 2015 10:16 pm
Hope you get this fixed! When you do don't leave your hand on the stick as it will wear out the bottom of the selector and cause "slop" only gently change gear in manuals and never "race" the box and it will out live you!
Post Posted: Mon Dec 28, 2015 9:38 pm
Ok thanks for all the help and advice :) I will pull it apart and have a look tomorrow, does anyone know where I can get the transfer case inner shifter boot is it the same as the transmission boot ? is it worth replacing the bushes with the brass ones ? or just replace them with the stock replacements ? does the transfer case use the same bushes ? thanks for all the help everyone :)
Post Posted: Tue Dec 29, 2015 12:27 am
Which boot are you referring to as the "inner"? Suzuki calls them #1 (on the transfer case or transmission) #2 (on the tunnel) and #3 (on the console - transmission only).
The #1 boots are only available (from Suzuki) with the shift levers, which makes them ridiculously expensive - what I have been using is steering rack boots - I choose one where the "inner pleat" diameter matches the neck on the shifter, cut it down and tie-wrap it to the shifter housing - you need to lube the small end (dishwashing liquid works well) to slide it over the "fat" section of the shift lever.
Post Posted: Tue Dec 29, 2015 12:31 am
I was talking about this kind of boot http://www.suzistore.com.au/four-wheel- ... etail.html
so I guess it's a no.1
Post Posted: Tue Dec 29, 2015 4:07 am
That is the #1 boot, but, what I find interesting is that Suzistore has it listed by a Suzuki part number - which means it is available separately from the shift lever, which is not how I recall it - I will have to recheck my parts catalogue.
My apologies for the confusion - on the SE series Vitaras, the transfer case shifter boot is available separately, the transmission shifter #1 boot is not, my car is SQ series, on which neither is available separately.
Post Posted: Wed Dec 30, 2015 6:25 pm
What is the best way to remove sand from the transfer case shifter ? it is in there because of the broken boot soon to be replaced :) and where can I get the retainer bolts for the shifters ? the 2 bolts that hold it in there ?
plan is a follows
http://www.suzistore.com.au/four-wheel- ... etail.html x2
http://www.zuksoffroad.com/Biscuit-5-sp ... _1591.html X1
and some of those bolts
Post Posted: Wed Dec 30, 2015 6:36 pm
Vacuum or Air Compressor.
Are you in Brisbane, I ask because I have a brand new Boot gearshifter I brought for my Vit but the old one was ok.
Post Posted: Wed Dec 30, 2015 10:52 pm
Air compressor it is then :) Nah I am about 3hrs north or Brisbane
Post Posted: Tue Apr 12, 2016 8:49 pm
This fix worked amazing thank you to all members involved I installed a Z.O.R lower bushing and a new upper bushing and a new transfer bushing fresh ixl grease and new rubber boots and it is like new
Vehicle: Vitara JLX 3 door hard top
Post Posted: Thu Apr 28, 2016 11:47 pm
I did this to mine as well as it was binding badly and made it hard to shift gears. I end up snapping the bottom one and replaced them all. It wasn't too expensive or difficult either and would recommend changing them if there is any play as it makes the car a lot better to drive :D
Users browsing this forum: No registered users and 101 guests
