It is currently Fri Aug 07, 2026 6:25 am
Vehicle: SJ70 Tintop, SJ51T, 97 Coily
Post Posted: Fri Jan 01, 2016 10:40 pm
I have an 87 Drover Tray back SJ51T with a 5 speed and a 1.3 motor. I thought this meant I had NT diffs with 3.9 gears and a NT transfer with the lower ratio? Is this correct or do I have WT ratio's all round?
Vehicle: sj51
Post Posted: Sat Jan 02, 2016 3:00 am
3.9nt diffs......
transfer is the same gearing as wt
I'm back..... Again
Post Posted: Sat Jan 02, 2016 9:56 am
cool thanks, so its a WT transfer with the handbrake drum on the transfer in this model?
Post Posted: Sat Jan 02, 2016 9:59 am
No, It's a NT transfer. An NT transfer has the same internal parts as a WT transfer but has the smaller yoke bolt pattern on the flanges and the rear drum handbrake. No WT has the drum handbrake.
All mechanical parts and case are the same, it's only the flanges and brake that are different.
Transfer ratios for WT and NT are 1.409 high range and 2.21 low range.
Users browsing this forum: No registered users and 38 guests
