| Confused with diff ratio's and transfer http://auszookers.com/forum/viewtopic.php?f=37&t=51640 |
| Author: | Bulldog 61 [ Fri Jan 01, 2016 10:40 pm ] |
| Post subject: | Confused with diff ratio's and transfer |
I have an 87 Drover Tray back SJ51T with a 5 speed and a 1.3 motor. I thought this meant I had NT diffs with 3.9 gears and a NT transfer with the lower ratio? Is this correct or do I have WT ratio's all round? Cheers |
| Author: | pezz [ Sat Jan 02, 2016 3:00 am ] |
| Post subject: | Re: Confused with diff ratio's and transfer |
3.9nt diffs...... transfer is the same gearing as wt |
| Author: | Bulldog 61 [ Sat Jan 02, 2016 9:56 am ] |
cool thanks, so its a WT transfer with the handbrake drum on the transfer in this model? |
| Author: | Gwagensteve [ Sat Jan 02, 2016 9:59 am ] |
No, It's a NT transfer. An NT transfer has the same internal parts as a WT transfer but has the smaller yoke bolt pattern on the flanges and the rear drum handbrake. No WT has the drum handbrake. All mechanical parts and case are the same, it's only the flanges and brake that are different. Transfer ratios for WT and NT are 1.409 high range and 2.21 low range. Steve. |
