i am currently in the process of removing my gearbox to replace the clutch.
im having quite a bit of trouble sliding it out as it seems to be really tight as if something is stopping it. i dont think ive missed any bolts anywhere as its pulled away from the motor with about a 5-10mm even gap all around.
maybe ive missed something? or is it just being stubborn and will take a bit of fiddling to release. it just seems too tight and i dont really wanna break anything.
What about the pressed steel cover that closes off the front/bottom of the bell housing. It's bolted to the bell housing but the flywheel is between it & the bell housing. Silverfox1111
Users browsing this forum: No registered users and 75 guests
