Vehicle: 93 swb vitara efi conversion
Posted: Tue Apr 12, 2016 10:28 pm
I have a 93 swb vitara and boughtsprings from King springs a supposedly 40mm lift for the front and has barely raised at all, so my question is should I just buy spacers for the springs and find springs that will lift the car more or would that make the ride too stiff?
The point behind my question is if you fit lift springs there must be a reason why you didn't get the expected lift - you need to determine what that is before proceeding...
Joined: Sun Jun 25, 2006 11:30 pm Posts: 2867 Location: here
Posted: Thu Apr 14, 2016 6:37 am
Measure the distance between the guard and the bottom of the rim, then others with the same vehicle can compare. Reason to measure to the rim is it negates tyre size or inflation differences.
As the vehicle is 20 odd year old it may have been lifted, did you get photos through the lift process or compare old and new springs
Measure from the bottom of the guard lip (highest point of the arch) to the centre of the wheel/hub. That's the way to compare heights to other vehicles. Measuring to the bottom of the rim causes incorrect height comparisons due to different rim diameters. Measuring to the centre of the wheel eliminates that issue, and it won't matter what size tyre or what tyre pressures they are running.
Users browsing this forum: No registered users and 28 guests
