It is currently Wed Sep 23, 2026 10:06 am
Vehicle: SWB Vitara G16B 1997
Post Posted: Fri Apr 15, 2016 5:40 pm
Hi, I am about to change the tailshaft seals and gonna change the oils in the diffs, transfer case and transmission at the same time, I am going with AMSOIL oils and theyre only available in quarts but how many litres will I need for the front diff, rear diff and then transfer case and transmission? I found an American page about the Geo Tracker which is meant to be the same car basically and Ill need around 4~up litres for the engine, 5~up litres for transmission and transfer case and 3~up litres for both diffs, is that about right? Getting the oils tomorrow so wanna make sure I don't overbuy as they're pretty expensive oils.
E: Its a G16B 97 Vitara SWB by the way
Post Posted: Fri Apr 15, 2016 6:01 pm
http://www.datateck.com.au/lube/castr_au/default.asp
Manual Transmission
Service Refill Capacity: 1.5 Litres.
Front Differential
Service Refill Capacity: 1.0 Litres
Rear Differential
Service Refill Capacity: 2.2 Litres
Transfer
Service Refill Capacity: 1.7 Litres.
Post Posted: Sat Apr 16, 2016 3:16 pm
Thanks Atari, got a gallon & quarter of engine oil, 4 quarters of trans fluids and 4 quarts of diff fluids for anyone wondering how much to get in American units, will edit post if it's not enough/too much.
Users browsing this forum: No registered users and 48 guests
