| Author |
Message |
Kor3y101
Joined: Tue Aug 18, 2015 6:50 pm Posts: 613 Location: Ipswich
Vehicle: 98 Jimny
 Posted: Wed Apr 13, 2016 2:54 pm |
Hey everyone.
So after getting a wheel alignment today I find that my front left shock absorber literally has oil coming out of it. So it's rooted!
Now my question is, I plan on doing a lift (next 6 months) so is it wise to buy the shocks to suit now and use them or buy another standard one?
Unfortunately my knowledge isn't great when it comes to that. I can possibly foresee there being an issue with its open length being too long and springs popping out?
Any advice would be great.
Jezza86
Platinum Supporter
Joined: Tue Dec 06, 2011 9:30 am Posts: 2155 Location: Nhulunbuy 0880
Vehicle: 2010 jimny
 Posted: Wed Apr 13, 2016 3:07 pm |
if you put 2" longer shocks in with stock springs you could get uncontrolled articulation, aka, your spring might fall out.
_________________ your daily dose of questionable sanity
Kor3y101
Vehicle: 98 Jimny
 Posted: Wed Apr 13, 2016 3:12 pm |
I figured this may be the case. Thanks Jezza!
watermouse
Vehicle: zook
 Posted: Wed Apr 13, 2016 3:21 pm |
Since decent shocks are 2/3rds the cost of a lift kit you may has well get the full lift done.
Zook_Fan
Joined: Thu Mar 13, 2008 10:30 pm Posts: 4531 Location: Toowoomba
 Posted: Thu Apr 14, 2016 7:18 am |
It's not that hard to measure. Unbolt your current shocks, ramp the car until the spring is loose in the mounts and check your extended length. Cross reference that with the extended length of the shock and see if it will still hold the spring tight. I'd be surprised if a dampener from a 2" lift would allow a stock spring to completely fall out.
Jezza86
Platinum Supporter
Vehicle: 2010 jimny
 Posted: Thu Apr 14, 2016 9:24 am |
few bounces, opposite side on bump stops, sprig rotating unloaded in its seat, its close enough to falling out that it better off avoided. monley did it, shot a rear spring out of his, luckely managed to get it back on the angle and poped the spring right back in by hand.
Zook_Fan
 Posted: Thu Apr 14, 2016 3:02 pm |
Didn't monley have an 80mm lift in it when he was popping springs?
shep
Joined: Thu Mar 29, 2007 11:30 pm Posts: 14498 Location: Here there everywhere
 Posted: Thu Apr 14, 2016 7:47 pm |
Spring retainers are pretty easy to make and fit
_________________ JEEPJEEPJEEPJEEPJEEPJEEPJEEPJEEPJEEP
Jezza86
Platinum Supporter
Vehicle: 2010 jimny
 Posted: Fri Apr 15, 2016 9:56 am |
Zook_Fan wrote: Didn't monley have an 80mm lift in it when he was popping springs? not sure what shocks he had with the springs.
