| Number of body mounts lwb vs swb http://auszookers.com/forum/viewtopic.php?f=37&t=52354 |
| Author: | Lebowski [ Fri Apr 22, 2016 3:30 am ] |
| Post subject: | Number of body mounts lwb vs swb |
I'm planning to replace the body mounts on my LWB. Most manufacturers only offer one kit....do LWB have the same number of body bushings? I was specifically thinking of the High Energy poly kit 1.4101, or maybe even their 1" body lift kit. Any advice? Thanks. |
| Author: | just_cruizin [ Fri Apr 22, 2016 7:07 am ] |
| Post subject: | Re: Number of body mounts lwb vs swb |
From the years of your vehicles it must be a Sierra Fixed mounts SWB - 10. LWB - 14 Non fixed mount about 6 more. Given you have both why didn't you just have a look? |
| Author: | Lebowski [ Fri Apr 22, 2016 7:50 am ] |
Haha....good question..... I'm on the road up north doing work travels. I'll probably be back home in about 2 weeks. So I'm sitting in a not so great motel planning the spring LWB re-build, and hope to order some parts in the next day. That way some of the parts should be there when I get back and I can get some stuff done before I have to travel again. Thanks for the info. |
| Author: | Gwagensteve [ Fri Apr 22, 2016 10:17 am ] |
Both have 6 captive studs. |
| Author: | just_cruizin [ Fri Apr 22, 2016 4:19 pm ] |
Shoot me a pm if you do end up chasing a body lift |
| Author: | Bulldog 61 [ Mon Apr 25, 2016 8:37 pm ] |
just_cruizin wrote: From the years of your vehicles it must be a Sierra Fixed mounts SWB - 10. LWB - 14 Non fixed mount about 6 more. Given you have both why didn't you just have a look? So if you do a body lift on a LWB should the non fixed mounts be replaced with longer ones as well?? |
| Author: | just_cruizin [ Mon Apr 25, 2016 9:39 pm ] |
Not necessarily, with the extra 4 locations it generally enough support to well and truely support the body |
