It is currently Mon Sep 21, 2026 5:45 pm
Vehicle: 92 vitara
Post Posted: Wed Apr 27, 2016 9:47 pm
Stupid question I'm doing my own body lift with polly in the lathe as I caint get the right height off the shelf do u need to keep existing rubbers or run the solid plastic chassis to body ??? Cheers in advance
Post Posted: Wed Apr 27, 2016 11:04 pm
The body lift is just s spacer, keep the rubbers & make the blocks a similar diameter.
Post Posted: Thu Apr 28, 2016 5:23 am
What height are you wanting
Post Posted: Thu Apr 28, 2016 8:12 am
how are you planning on getting around the captive stud length? making your own female bolts?
Vehicle: 92 vitara
Post Posted: Thu Apr 28, 2016 10:36 am
Yeah I'll have to cut floor and put in tubes sleaves it'll be about 90mm height to fit 1uz was just unsure if u are meant to keep original rubbers too
Vehicle: 91 citara 2 door jlx
Post Posted: Thu Apr 28, 2016 9:22 pm
i use 1/2 inch high tensile bolts and drill thru them length ways and tap them out to make female thread nuts that u can screw onto existing captive bolts hanging down from body
Post Posted: Thu Apr 28, 2016 11:06 pm
1/2" (12.7mm") won't leave enough meat to tap.
The factory sleeve through the rubber is 16mm OD. I use a 16mm bolt and drill the washers out from 10mm to 16mm.
In any case, I would advise strongly against a 90mm body lift and I imagine that no engineer in Australia would pass one.
Vehicle: Vitara 1994
Post Posted: Sat May 14, 2016 6:08 pm
calmini do a 3 inch body lift. If you can make that work it would be best
Post Posted: Sat May 14, 2016 6:19 pm
you must really hate the OP i wouldn't wish that upon anyone... it's a load of calamity. pompoms
Post Posted: Sun May 22, 2016 10:41 pm
Kkkk
Despite the fact I would never buy it, I still think it would be better than a home made 90mm BD
Vehicle: SWB Vitara
Post Posted: Sun May 29, 2016 2:56 pm
This OP. Or shape the lift blocks to replace the existing rubbers like this:
http://www.bits4vits.co.uk/store/vitara ... _1241.html
Post Posted: Sun May 29, 2016 10:54 pm
Never do this.
Body lift blocks should be very hard polyurethane or aluminium such the the only flex is via the factory body rubber. If you use the 'all in one' type block either they will have too much flex and allow the body to roll excessively or be to rigid and provide a rough ride and potentially damage the body.
Users browsing this forum: No registered users and 73 guests
