It is currently Sat Aug 01, 2026 7:54 pm
Vehicle: Suzukiless these days..
Post Posted: Mon May 16, 2016 5:54 pm
Some one have the time to measure the width of their radiator?
Bought 2 that should fit, they are both miles to wide.....
Wonder how I managed to score a narrow one..
goddamitmyspacebarsbrokenagain
Post Posted: Tue May 17, 2016 12:47 pm
From memory the one you want is around 540mm. If you look on ebay do not buy a "heavy duty" unit, no idea what they fit but it's not a SQ625.
Post Posted: Tue May 17, 2016 1:03 pm
read this clusterfuck from old mate geckoxl7, there is some tech in there i think. viewtopic.php?f=37&t=48391&hilit=radiator
Post Posted: Tue May 17, 2016 7:28 pm
Ok men, ladies, noobs, and ATARI....(thanks for all your search and help stuff Gus... Your still make AZ worth while)
:beer: :beer: :beer: :beer: :beer: :beer: :beer: :beer:
AFTER THINKING OF SHEPPING THE SHIT BOX...AND TWO CALLS AND ONE VISIT TO SUZUKI ..
There are two radiators that will fit the Grand vitara,
Depending on motor, gearbox, aircon combo...also depending on how far through the series they were...
98-02 aircon, v6, either box with 2lt 4cyl or 2.5 v6 in both LWB and SWB,
Radiator must be the
525wide, 425high, 28thick.
(Same radiator as the sq420 also same radiator between 2 and 4door)
01 -03 depending on we're they were destined to be registered/ sold
LWB WAS INLY ONE LISTED..
Either as above
Or
595 wide, 425 high, 26 thick are the only two possible dimensions..
SWB is the 525,425,28
After mid to late 02 to end of run only the 595,425,26 will fit , Again LWB was only one listed.
eBay does sell both these radiator in a 3 core version which is 50mm thick but it means removal of clutch fan and shroud..
All the new replacement radiators will come with nuts to bolt shroud to....best fitting nut is. M6 in 25mm
The XL7s seem to as much of a mismatch,, couldn't be arsed looking at all the info on them as it doesn't apply..
In SA Sprint Autos were the best price and quality PROTEX $216.20
There was one cheaper OPTION but it looked like a rough job..$156.00
Hope this helps someone in the future!
Post Posted: Tue May 17, 2016 7:47 pm
TLDR :thefinger:
Post Posted: Tue May 17, 2016 8:19 pm
Chop wrote:
TLDR :thefinger:
LOL... Not relevant to you know is it?.
Users browsing this forum: No registered users and 121 guests
