It is currently Mon Sep 21, 2026 6:30 pm
Vehicle: 6.5s, gti, 31 extremes
Post Posted: Sun May 29, 2016 11:54 am
Hey guys,
thinking of doing dual battery setup in the wagon for those weekends away.
anyone mounted a battery under the middle/rear seats in an xl7? I've got some vrla (agm) batteries in my camper thinking about mounting one on its side under the seat
Anyone got any other ideas
Nic
Vehicle: 2004 GV sport v6
Post Posted: Mon May 30, 2016 9:19 pm
why mount it under the seats when you can put it under the bonnet I've got a 2004 gv with an 85 amp hour optima yellow top under the bonnet .
Sent from my SM-N920I using Tapatalk
Post Posted: Mon May 30, 2016 9:47 pm
Send a pic of ur engine bay. I would have to move washer bottle and overflow bottle at minimum
Post Posted: Tue May 31, 2016 3:42 am
Later models of the GV (he has a 2004) have the washer bottle in the front guard, which makes it easier to do a dual battery under the hood.
Post Posted: Tue May 31, 2016 6:38 am
If a second battery can be fitted under a new jimnys bonnet then a GV should be easy.
Post Posted: Mon Jun 06, 2016 10:54 am
Yes, I had a pair of 23A/h (IIRC?) AGM's paralleled together and fixed into a Maxi Bin. To put them under the seat I'd lift up the bar that you use to slide the middle row; the Maxi Bin would fit under with it lifted, but once released it wouldn't slide back out.
The controller was a kit one from Jaycar (no longer available) that relied on resistance in the cabling to the battery for voltage feedback. So a good kit given the length of the cable run from the controller to the middle row seat. If I was doing it again I'd use a DC-DC charger.
Users browsing this forum: No registered users and 65 guests
