It is currently Wed Sep 23, 2026 10:04 am
Vehicle: 97 maruti ute
Post Posted: Fri Jun 03, 2016 9:18 pm
Hi guys
I've just been given a seat of mint vt Calais seats..
So I figured what better car to put them into then a stockman lol
Has anyone had luck fitting Commy seats?
Vehicle: Coily.
Post Posted: Fri Jun 03, 2016 9:37 pm
...you mean fit one and use it as front bench seat,you'll have to cut a hole for the handbrake.
Post Posted: Fri Jun 03, 2016 10:37 pm
I actually meant the two front seats..
I take that as they're too wide then?
Post Posted: Fri Jun 03, 2016 11:42 pm
Yes, it's been done.
No, I'm not sure ts a good idea.
Vehicle: Coily.
Post Posted: Sat Jun 04, 2016 9:56 am
Yeah,a bit big,i'm surprised someone has done it as you would be too close to the steering wheel even if you could squeeze them in lenghtways.
Post Posted: Sat Jun 04, 2016 10:25 am
Only adviseable for a midget, width may also be an issue
Post Posted: Sat Jun 04, 2016 2:09 pm
Well I'm only 5'8", so might give it a closer inspection next weekend
Maybe it will work if I only put the drivers side in...
Cheers for the help lads
Vehicle: 2020 Vitara Turbo
Post Posted: Tue Jun 07, 2016 9:42 pm
S13 Silvia/ 180sx seats have done me well, I'm about the same height as you. Last pair I picked up were from a 180sx, velour tiger trim and was $20 for the pair.
Vehicle: LWB Sierra & XL7
Post Posted: Tue Jun 07, 2016 10:19 pm
I went with Baleno seats and even then, they're a bit of a squeeze. I definitely sit a bit higher, lucky i'm a short bastard.
'92 Vitara & Camper trailer
Post Posted: Wed Jun 08, 2016 8:54 am
I found the same. I'm 5'11. I definitely wouldn't want them to sit any higher.
