http://auszookers.com/forum/
Grand vitara roof rails bit loose??
http://auszookers.com/forum/viewtopic.php?f=37&t=52584
Author:  cbzook [ Sat Jun 04, 2016 5:08 pm ]
Post subject:  Grand vitara roof rails bit loose??
Hey guys,
One of my factory roof rails seems a fraction loose and ideas on how to tighten?
Author:  fordem [ Sat Jun 04, 2016 11:51 pm ]
Post subject:  Re: Grand vitara roof rails bit loose??
Which of the GVs do you have - SQ or JB/JT?
The SQ series rails are a hollow aluminum extrusion with cast feet that are assembled with some sort of adhesive that fails as it ages, I disassembled mine and drilled through the foot and the extrusion and fitted a screw & nut - BUT - if I had to do it over, I would just clean everything up and reassemble with some sort of silicone adhesive as the joint between the extrusion & the foot sits at an angle that is dictated by the curve of the roof.
Author:  cbzook [ Sun Jun 05, 2016 9:05 am ]
Yea I have the sq model, will have a look at what you mentioned
