| Rear diff lock sv620 http://auszookers.com/forum/viewtopic.php?f=37&t=52636 |
| Author: | Bluezook85 [ Mon Jun 13, 2016 6:37 pm ] |
| Post subject: | Rear diff lock sv620 |
Hey all, quick question, lock rite 1510. Will it work in a sv620. Yes or no? Thanks to anyone who can tell me. |
| Author: | shiv [ Mon Jun 20, 2016 8:34 am ] |
| Post subject: | Re: Rear diff lock sv620 |
also this might be helpful http://nbs4x4club.com/forum/index.php?t ... 374.0;wap2 Quote: RobM:
Auto Locker Info for Vitaras........cont'd Hopefully some helpful info for future reference: 1. The most common 4PIN Suzuki Sierra #1510 Lock-right AutoLocker does fit into the Vitara REAR or FRONT 2PIN Vitara Diff 2. For FRONT installation, u need to source the Shaft Block (ie: small block that the Pins slide through in a 4PIN Diff) that u find in the 4PIN Diffs as this is a important part in making the locker work at all. 3. The Auto locker will work using either Sierra or Vitara Sidegears..... the only difference I found is that maybe the use of the Vitara sidegears results in a louder ratching noise from the diff.... but this maybe minimized by using a heavier grade of Diff oil ?. 4. If upgrading to 26spline axles, then u may have to shorten the LHS by some 7mm. {Not sure if the 26spline axles out of the later V6 Vitaras are any different in length but the GV ones are definitely longer} Hope this helps someone in the future...... cheers... rob |
| Author: | Bluezook85 [ Mon Jun 20, 2016 8:41 am ] |
Sweet as, cheers Rob. I'm only looking at locking the rear atm as I can't be stuffed with a steel diff conversion. Thanks for the info mate. |
