http://auszookers.com/forum/
New Memeber from WA
http://auszookers.com/forum/viewtopic.php?f=37&t=52837
Author:  LittleDoubleDiff [ Mon Jul 18, 2016 1:12 am ]
Post subject:  New Memeber from WA
Just joined and like to say hello,, I bought a Sierra 1996 Coily this weekend so I am the Noob,,,,.
It’s got 160k on the clock, generally tidy needing some love and seems in reasonable condition, slight smear of surface rust as like a previous owner has been down the beach but no deep imbedded rust if you know what I am trying to say.
It’s unregistered and has a lift kit that looks poorly done with some of the spacers / block missing. So I will re-do the lift or drop it back to standard for registration depending on the legal requirement here in WA. (as I understand 50mm is OK)
The tyres and are 235/75-15R and the rims seem to be wider so I have to find out how that goes down with re-rego so I guess the combination maybe bit of a challenge.
The vehicle has Rancho shocks & King springs so looking at the web sites that doesn’t make sense, kings do make springs for a 1996 coily but Rancho don’t make shocks,, well not showing now.
Thoughts are to split the body off the chassis, replace the suspension arm bushes, fix the damage from the half done lift kit, sand blast and recoat the chassis for a fresh start.
While split I will clean up and repaint all the running gear, under body and go crazy happy time with bitumen paint for that longevity.
Anyhow I will be stalking around the forum as this venture progresses. :peaceout: :deadhorse:
Author:  bumstein [ Mon Jul 18, 2016 11:51 am ]
Post subject:  Re: New Memeber from WA
Welcome LDD!! Sounds like you've got yourself a cracker project!!
Make sure you post pics, start a thread for your jalopy in the 'Rigs of Auszookers' section and show us the progress!!
Author:  MrRocky [ Mon Jul 18, 2016 5:39 pm ]
Gday mate, the wa branch of az isnt the most active of states thats for sure as is evident by the trip threads ;)
Jump on the perth suzuki offroad fb page for trips once your ready to get your rig out and about. A few guys on there with coily bits and bobs
Author:  LittleDoubleDiff [ Wed Jul 20, 2016 10:21 pm ]
Cheers for the feedback,,, Did some investigation and looks like I will get it over the pits OK.
I also checked out the cost of galvanizing the chassis at $450 so that’s on the cards.
Over the next few month,,, up to 6 or so I will post the revival of the Gazooka 
Author:  MrRocky [ Thu Jul 21, 2016 6:30 pm ]
Galv adds a fair bit of weight im led to believe.
Also coily susp/chassis brackets have a tendency to crack and tear meaning you will have to grind the galv off and reweld/strengthen.
A bottle of fish oil will do the same job
Author:  bumstein [ Thu Jul 21, 2016 8:28 pm ]
If your keen to do a rolls Royce job, have a look at POR15
http://www.ppcco.com.au/por06.html
