http://auszookers.com/forum/
89 zooki gear box
http://auszookers.com/forum/viewtopic.php?f=37&t=52913
Author:  tanked [ Wed Aug 03, 2016 6:04 pm ]
Post subject:  89 zooki gear box
Hello all i need some help. IF this has been bought up please link m. The front seal on the gearbox is leaking pretty awesomly, if someone has redone the front seals in the box please some advice, I dont want to jump straight into it that all, Thanks all
Author:  Blkfxx [ Wed Aug 03, 2016 9:04 pm ]
Post subject:  Re: 89 zooki gear box
FSM - https://ia600201.us.archive.org/26/item ... Manual.pdf
Author:  steve125 [ Fri Aug 05, 2016 4:23 pm ]
The seal itself is easy, getting the gearbox out can be a pain, my exhaust was in the way so had to twist box 45 degrees (can't remember which way) so it would drop past the engine block. And take a photo/mark the clutch lever/cable position so you can re-install it the same way.
Author:  cairns27 [ Fri Aug 05, 2016 7:41 pm ]
The gearbox is in the car ??... usually it's the rear main seal.
bye
Author:  steve125 [ Sat Aug 06, 2016 6:02 am ]
Thought mine was the main seal, turned out to be the gearbox.
