| GV 26 spline drive shaft in a vitara http://auszookers.com/forum/viewtopic.php?f=37&t=52918 |
| Author: | gone.west [ Thu Aug 04, 2016 11:24 pm ] |
| Post subject: | GV 26 spline drive shaft in a vitara |
Hi guys, I have a buggared RH driveshaft on my 96 vitara. The front diff is a bitza. Steel main housing, ally centre/3rd arm housing. 5.12 gears and 26 spline side gears. (don't know is full diff centre change or side gear changed. (no locker) Im struggling trying to find a replacement full shaft (spline to spline) for a vitara with a 26 spline inner shaft. Will the RH drive shaft form a GV vitara fit? besides the 22 vs 26 inner spline is there other differences with the vitara vs GV shafts? |
| Author: | fordem [ Fri Aug 05, 2016 12:14 am ] |
| Post subject: | Re: GV 26 spline drive shaft in a vitara |
As far as I know the GV shafts are longer, and the inner CV splined stub is also longer. |
| Author: | gone.west [ Fri Aug 05, 2016 2:38 pm ] |
Cheers. I have a new 22 spline shaft. Can I just pop the inner CVs and put the 26 spline CV on the new shaft? |
| Author: | VitNick [ Sat Aug 06, 2016 9:07 am ] |
Gone.west I've tried that and the bearing cages at least in mine wouldn't swap over and a few other things stopped it. It's been awhile since I tried so can't remember what else there was. |
| Author: | zuk94 [ Sat Aug 20, 2016 10:24 pm ] |
If its just the outter side thats broke just swap the end over, that is if its just the cage thats broken. |
