It is currently Mon Aug 10, 2026 6:42 pm
Vehicle: stockman
Post Posted: Fri Aug 26, 2016 11:47 pm
Any ideas of the most km's people have seen on 2.5 Grand Vitaras? Before engine needs rebuild?
Vehicle: stockman
Post Posted: Sat Aug 27, 2016 9:25 pm
So no one here as seen or owned very high milage Grand Vitaras 2.5 V6??? I have seen Ford falcon ex taxis with 990000km on the clock!
Post Posted: Sat Aug 27, 2016 10:19 pm
They'll make near on 500,000kms! But the reality is, most people never look after them properly to get that out of them. I got rid of my 2003 with 248,000kms and still ran extremely well. But I always dropped the oil every 5000kms and had no timing chain rattle.
Biggest issue with these motors is the timing chain/guides and oil leaks.
Vehicle: stockman
Post Posted: Sat Aug 27, 2016 11:15 pm
Did you use 5W30 OIL?
Post Posted: Sun Aug 28, 2016 10:12 am
15w40 semi synthetic which was the same as suzuki used. Except they used castrol magnetec.
Post Posted: Sun Aug 28, 2016 10:30 am
How long you can get out of a motor now will be entirely dependent on how it was treated before you got it. Taxis get high kms out of their motors because they almost never cold start them.
Vehicle: zook
Post Posted: Sun Aug 28, 2016 11:30 am
The total value of a mid to high KM Grand Vitara would probably be less than the cost of an engine rebuild making it somewhat uneconomical to do.
Post Posted: Sun Aug 28, 2016 11:41 am
Lots of truth here.
This is just the reality of car ownership. If the whole car is worth $4K, the amount any sane person will spend on a rebuild will be significantly less than this, because lets be honest, if the engine is worn out, most of the rest of the car isn't far behind.
I imagine a proper rebuild on a 2.5 GV is relatively speaking, stupid expensive. There's lots of moving parts in that engine.
Post Posted: Sun Aug 28, 2016 4:05 pm
Yes ain't that the truth, you can see why they also cost alot to have work done on them. When I pulled mine out to do the rear main and fix up all the other leaks you soon find out how much has to be pulled apart even to do small things. Worst experience I've had working on an engine when it has had to be removed from car.
Vehicle: Suzuki 2003 Xl7
Post Posted: Fri Sep 09, 2016 9:15 pm
My 2.7 2002 xl7 is at 355000. I get a valve tick on start up for about 10 seconds about 7500k after each service. Works like a timer to tell me it's due again.
Users browsing this forum: No registered users and 104 guests
