It is currently Wed Aug 12, 2026 2:25 am
Vehicle: Suzuki sierra sj70
Post Posted: Sat Oct 08, 2016 10:41 pm
Hi everyone, is anyone on here from WA that can wire in a G16B into a sj70, i'm having heaps of issues.
Been using warbirds guide but things don't seem to be adding up, I may even have the wrong ECU and/or wiring harness.
Thanks in advance, Tom.
Post Posted: Sun Oct 09, 2016 12:46 pm
What g16b motor is it ?
Im in wa and can do full plug and play baleno g16b harness but dont do the vitara g16 ones.
Vehicle: 2020 Vitara Turbo
Post Posted: Sun Oct 09, 2016 1:08 pm
The warbirds manual only covers series 1 vitara, not series 2 which runs a different loom/ecu/afm/injectorloom.
Post Posted: Sun Oct 09, 2016 4:12 pm
I'm starting to think that's my issue. it must be a series 2 as i have the 5 pin afm and the injector loom doesn't match up what so ever with his write up, I also have a 2 pin dizzy :(
Is it still possible to do the conversion?
Post Posted: Mon Oct 10, 2016 7:45 pm
I'm thinking that's what my issue is, would you know if the swap is still possible, would i just need an obd2 diagram and work it out from there or do i need to swap components over?
Thanks for the replies.
Post Posted: Tue Oct 11, 2016 8:53 pm
WHY ARENT MY REPLIES BEING POSTED!!!!!!!!!
Vehicle: Which one?
Post Posted: Thu Oct 13, 2016 9:02 am
Turn the volume down; new members join a moderation queue that needs to be approved.
Post Posted: Thu Oct 13, 2016 8:14 pm
I've done both series Vitara, the 2nd series being easier then the first. Depending on how literate you are with wiring diagrams, I can put up the ecu pinouts for the 2nd series. You'll have the hotwire AFM if it is, and the smaller Dizzy cap.
edit :
series 1 is the 5 pin AFM that is the vane type.
series 2 is the hotwire afm which is 3 pin.
