Joined: Sun Jun 25, 2006 11:30 pm Posts: 2867 Location: here
Posted: Fri Oct 28, 2016 7:23 pm
There was a good discussion on FB about this this week. Basically any sill replacement MAY constitute a 'write off'.
That said if it's done to a good standard it may not be noticeable and return the integrity of the body. I've previously used 100x100 SHS which also matchs the factory lines and sits just below the footwell level and when pressed against the inside panel protrudes about 10-15mm.
Others have used smaller sections and different profiles such as silo profile and flat bar to create the 45 degree 'boat sills'
Users browsing this forum: No registered users and 110 guests
