It is currently Wed Sep 23, 2026 2:37 pm
Post Posted: Mon Apr 24, 2017 10:04 am
Just fell into a bit of a washout taking a pump down to the creek, and it started clunking.
Please tell me I can just put a bolt through it..gotta go out for a while so will just twitch it for now.
tar
bye
Post Posted: Mon Apr 24, 2017 2:14 pm
bolt/ratchet strap, Even a new mount would help
bYe
Post Posted: Mon Apr 24, 2017 3:20 pm
+1 on new mount.
Bye
Post Posted: Mon Apr 24, 2017 3:25 pm
What's happened to the mount? Has it snapped? Is it the bracket or the rubber mount?
On one of my old jalopys I got away with no mount for a while. But it's not ideal. Get one as soon as you can
Post Posted: Mon Apr 24, 2017 3:26 pm
Post Posted: Mon Apr 24, 2017 4:30 pm
Yeah I'll mainly park up till I get a new one. It was the LHS one with steel glued to the rubber.
thanks
bye
Post Posted: Fri Apr 28, 2017 5:42 pm
I got a new t'fer mount from FNQ Filters and Spares in Mareeba, part Transgold TEM0235, and the studs were 3 or4 ml longer. I was about to get a knife blade to it, and decided to get a hammer first, and it went in. Will be a drama replacing it next time, I wish now I had cut the studs.
bye
Post Posted: Fri Apr 28, 2017 5:44 pm
Which you will need to in 5...4...3....
Only genuine Bridgestone mounts last.
Post Posted: Fri Apr 28, 2017 5:47 pm
It cost $38.00, I's only the second time I've broken it in ten years.
bye
Post Posted: Fri Apr 28, 2017 6:22 pm
So the other mounts are also non genuine?
Post Posted: Sat Apr 29, 2017 6:23 am
Can't remember, but a friend rebuilt the t'fer box for a few years ago. Des at Briktec motors on Supply Road, Edmonton, has also looked at it. The handbrake drum almost touches the chasis. Neither thought the bracket was bent, and it has not vibration. Des is the Suzisport agent, and does know a lot about Suzukis
bye
Users browsing this forum: No registered users and 41 guests
