It is currently Wed Sep 23, 2026 6:54 am
Vehicle: Suzuki Grand Vitari 04
Post Posted: Mon May 01, 2017 6:36 am
G'day, can anyone tell me which wire colour is the high beam wire on a 2004 1.6 Vitara 3 door. I have run all the wiring, switch etc, connected to the wire I had been told was the high beam, but it does not seem to be the right wire. So I need some help with the wire colour.
Thanks,
Richard
Post Posted: Mon May 01, 2017 10:39 am
Red - but - are you aware that Suzuki headlights are negative switched and require the relay coil to be wired differently?
Post Posted: Mon May 01, 2017 3:47 pm
I have a relay in the line but I did not know it has to be wired differently. that should be the problem, I will try that,
thanks.
Vehicle: GV1600SE-2005
Post Posted: Mon May 01, 2017 6:55 pm
This should do it..
Post Posted: Tue May 02, 2017 4:55 pm
Great, that drawing is what I need. I got a Suzuki diagram but it didn't show the relay.
Thanks.
Users browsing this forum: No registered users and 46 guests
