http://auszookers.com/forum/
Noob here
http://auszookers.com/forum/viewtopic.php?f=37&t=54307
Author:  Darcy'sdad [ Wed Jun 14, 2017 10:03 pm ]
Post subject:  Noob here
Hey guys just recently picked up a 95 vitara Lwb and installed a 2 inch lift pretty much straight away but it made my tyres look tiny (215/75 15 on 15x8) just wanted to know what sort of size I should stick to when going bigger but also not sacrificing on road "performance" it's a bit of a slug anyways
Author:  Gwagensteve [ Fri Jun 16, 2017 6:21 pm ]
Post subject:  Re: Noob here
Wow - a 215 on a 15X8? Cripes, that must be stretched something crazy.
Anyways, It's just a sliding scale. You're currently 1" larger than stock. Next step is 235 75 15 which is another 1" larger. Each step you're going to notice a drop in acceleration and braking performance. I can't really tell you how much is too much - I know people who drove stock Vitaras on 33's, but that doesn't make it right. you should be OK on a 235 75 15.
In any case, I'm not one to comment on aesthetics. Suspension lift is really only to increase compression travel, so the reason to run it is if you're suffering from excessive "blowing though" to the bumpstop. It's not connected to tyre size.
Author:  vet 180 [ Sat Jun 17, 2017 11:05 am ]
^^^ this, plus ground clearance are the only reasons. Is you car auto or manual?
Author:  Gwagensteve [ Sat Jun 17, 2017 3:05 pm ]
Suspension lift does not increase ground clearance for a live axled vehicle.
Author:  Scrawny [ Sat Jun 17, 2017 5:49 pm ]
But it will help ever so slightly on the front of a Vit
Author:  Gwagensteve [ Sat Jun 17, 2017 6:26 pm ]
It will help the front miss the obstacle the rear diff hits. :wink:
Author:  Darcy'sdad [ Thu Jun 22, 2017 10:22 pm ]
Manual estate wagon and it turns out they are 15x7 not 8 just got a job as a tyre fitter and measured and checked them myself my workmate said he ran 31x10.5s on his without trouble but I think I'll just stick with 30x9.5 or 235/75
Author:  rustyzook [ Tue Jun 27, 2017 5:34 pm ]
That works. The front diff is made of a mild cheese, the rear is pretty solid :lol:
