| Author |
Message |
rmd1
Vehicle: 96 vitara v6 lwb
 Posted: Wed Aug 30, 2017 10:50 am |
Looking to put some lights on the from roof rack on my 96 lab and I'm after some ideas on how to get the wiring to the roof. I don't really want to drill any holes and looking at it I can't think of a way to get wiring up there. Any ideas or suggestions will be greatly appreciated
Gwagensteve
 Posted: Wed Aug 30, 2017 10:54 am |
There's not really a clean way without drilling a hole somewhere.
atari4x4
 Posted: Wed Aug 30, 2017 10:57 am |
no holes required.
peel back the rubber molding that runs along the pinch weld on the roof & run it up from the engine bay & up the A pillar.... same goes with the rear, remove the plastic trim on the D pillar & run it in the rubber molding.
would be pics in my build thread, but they is borked.
Gwagensteve
 Posted: Wed Aug 30, 2017 11:26 am |
rmd1
 Posted: Sun Sep 03, 2017 10:18 pm |
Thanks for the info got my lights wired up now I just need to find somewhere to run wires through the firewall to put a switch in
greavesyzook
Joined: Fri Apr 01, 2016 9:22 pm Posts: 359 Location: Victoria "south Gippsland"
Vehicle: 1992 suzuki sierra hardtop
 Posted: Mon Sep 04, 2017 9:42 am |
There a hole near the master cylinder
rmd1
 Posted: Mon Sep 04, 2017 10:35 pm |
Found a hole in the grommet under the master cylinder worked perfect
greavesyzook
 Posted: Sun Sep 17, 2017 6:00 pm |
Yep it's in a good spot there
Dalahare
Vehicle: 1997 2.0 JLX 3dr
 Posted: Mon Sep 18, 2017 11:27 am |
I drilled halfway through the rubber trim in about 4 spots and ran cable ties through it to hold the wiring for the light bar as it was too thick to hide underneath, work pretty well.
