| wiring to roof http://auszookers.com/forum/viewtopic.php?f=37&t=54531 |
| Author: | rmd1 [ Wed Aug 30, 2017 10:50 am ] |
| Post subject: | wiring to roof |
Looking to put some lights on the from roof rack on my 96 lab and I'm after some ideas on how to get the wiring to the roof. I don't really want to drill any holes and looking at it I can't think of a way to get wiring up there. Any ideas or suggestions will be greatly appreciated |
| Author: | Gwagensteve [ Wed Aug 30, 2017 10:54 am ] |
| Post subject: | Re: wiring to roof |
There's not really a clean way without drilling a hole somewhere. |
| Author: | atari4x4 [ Wed Aug 30, 2017 10:57 am ] |
no holes required. peel back the rubber molding that runs along the pinch weld on the roof & run it up from the engine bay & up the A pillar.... same goes with the rear, remove the plastic trim on the D pillar & run it in the rubber molding. would be pics in my build thread, but they is borked. |
| Author: | Gwagensteve [ Wed Aug 30, 2017 11:26 am ] |
Ah- vitara. Missed that. |
| Author: | rmd1 [ Sun Sep 03, 2017 10:18 pm ] |
Thanks for the info got my lights wired up now I just need to find somewhere to run wires through the firewall to put a switch in |
| Author: | greavesyzook [ Mon Sep 04, 2017 9:42 am ] |
There a hole near the master cylinder |
| Author: | rmd1 [ Mon Sep 04, 2017 10:35 pm ] |
Found a hole in the grommet under the master cylinder worked perfect |
| Author: | greavesyzook [ Sun Sep 17, 2017 6:00 pm ] |
Yep it's in a good spot there |
| Author: | Dalahare [ Mon Sep 18, 2017 11:27 am ] |
I drilled halfway through the rubber trim in about 4 spots and ran cable ties through it to hold the wiring for the light bar as it was too thick to hide underneath, work pretty well. |
