It is currently Mon Sep 21, 2026 6:13 pm
Vehicle: 96 vitara v6 lwb
Post Posted: Wed Aug 30, 2017 10:50 am
Looking to put some lights on the from roof rack on my 96 lab and I'm after some ideas on how to get the wiring to the roof. I don't really want to drill any holes and looking at it I can't think of a way to get wiring up there.
Any ideas or suggestions will be greatly appreciated
Post Posted: Wed Aug 30, 2017 10:54 am
There's not really a clean way without drilling a hole somewhere.
Post Posted: Wed Aug 30, 2017 10:57 am
no holes required.
peel back the rubber molding that runs along the pinch weld on the roof & run it up from the engine bay & up the A pillar.... same goes with the rear, remove the plastic trim on the D pillar & run it in the rubber molding.
would be pics in my build thread, but they is borked.
Post Posted: Wed Aug 30, 2017 11:26 am
Ah- vitara. Missed that.
Post Posted: Sun Sep 03, 2017 10:18 pm
Thanks for the info got my lights wired up now I just need to find somewhere to run wires through the firewall to put a switch in
Vehicle: 1992 suzuki sierra hardtop
Post Posted: Mon Sep 04, 2017 9:42 am
There a hole near the master cylinder
Post Posted: Mon Sep 04, 2017 10:35 pm
Found a hole in the grommet under the master cylinder worked perfect
Post Posted: Sun Sep 17, 2017 6:00 pm
Yep it's in a good spot there
Vehicle: 1997 2.0 JLX 3dr
Post Posted: Mon Sep 18, 2017 11:27 am
I drilled halfway through the rubber trim in about 4 spots and ran cable ties through it to hold the wiring for the light bar as it was too thick to hide underneath, work pretty well.
Users browsing this forum: Google [Bot] and 69 guests
