It is currently Mon Sep 21, 2026 8:43 am
Vehicle: 89 suzuki sierra
Post Posted: Wed Sep 13, 2017 6:00 pm
I know there is many many many threads out there and read alot of them already. However looking to upgrade engine in mighty sierra, most common is g16b as its pretty much bolt in some wiring and happyness. However they are getting to be an older motor and getting less common. They question i have is there something made this century that will bolt in pretty easy. Now i know nothing will bolt in and there will have to have some creation to make it work. I dont want to spend a crazy amount to make it work, working at a wrecking yard i have access or least contacts to get engines wiring etc etc. Ideally talk to someone who has done it before. I am not looking for a crazy engine swap or anything like that just after something newer.
Post Posted: Wed Sep 13, 2017 6:18 pm
M13/15 is acheivable using only bolt on parts/mounts.
Suzistore have done a couple
Post Posted: Wed Sep 13, 2017 6:20 pm
Short answer- G16b
Long answer- sure- have a crack at an M motor. It can (and has) been done, but there's more to a engine conversion than how new it is. Like gearbox. And immobiliser. And stuff.
Vehicle: 91 Tin Top
Post Posted: Wed Sep 13, 2017 7:25 pm
Another thread that Photobucket fucked, but it will still give you some idea of what's required for one of the M series conversions. Each one is a little bit different remember....
http://www.auszookers.com/forum/viewtopic.php?t=10300
Post Posted: Wed Sep 13, 2017 7:59 pm
thanks pete79.. stupid photobucket....Is there anyone in the brisbane area that has done it before?? would like to look before i leap...
Post Posted: Thu Sep 14, 2017 5:54 pm
hmm what about doing a micro squirt setup on a g16a? anyone played with the systems before?
Post Posted: Thu Sep 14, 2017 7:37 pm
Same if not more effort than g16b for what will feel like half the power. Theres a stack of sub 150,xxx km balenos with stuffed manual boxes in wa not sure about your part of the world but any efi motor swap is going to require $$$ to get it going. Id budget 3k to get a decent g16b motor in and running with a new clutch/seals/fuel pump/ect...
Post Posted: Thu Sep 14, 2017 10:04 pm
Why on earth would you aftermarket inject a g16A? They're rare and far too expensive (and the worst motor Suzuki has made)
G16B baleno, and gearbox in order of desirability:
Adapter and sierra gearbox
Vitara manual
Trimatic
Aw-4
Vehicle: 91 Tin Top
Post Posted: Fri Sep 15, 2017 12:21 am
Vitara manual
Trimatic
Aw-4
Wait. Hang on a minute....
Who is this guy and what has he done with Gwagonsteve?
The real Gwagon would never put an AW-4 at the bottom of his gearbox list.... ;)
Post Posted: Fri Sep 15, 2017 5:32 am
Oh, yes, that wasn't clear. Input them in order from least to most desirable. Ha!
Vehicle: WT sierra, GU CRD
Post Posted: Fri Sep 15, 2017 9:59 am
How "hard" is the traumatic compared to AW4?
I love ZD30. :)
Post Posted: Fri Sep 15, 2017 11:21 am
Much easier- it's shorter, obviously only requires vacuum, TV, reverse lights and start inhibitor connected.
However, they're very difficult to gear for on road use (and even harder for on and off road use)
Post Posted: Sun Sep 17, 2017 10:13 am
On a side note I was at a wrecker on the weekend and seen a g13b if anyone is interested in it priv message me I will tell you which wrecker..
Users browsing this forum: No registered users and 63 guests
