It is currently Mon Sep 21, 2026 7:55 am
Vehicle: suzuki sierra 1995 SJ70
Post Posted: Sat Dec 23, 2017 10:55 am
Seem too have issue wuth car stalling once clutch has been released past half way......will take off with clutch half out but minute released completely will stall.
We seem too think its electrical and may think its related to the CLUTCH STARTING SWITCH?
any helkp / ideas will be appreciated....thanks in advance......
Post Posted: Sat Dec 23, 2017 11:05 am
Not sure what car you drive but try disconnecting the switch, if that doesn’t work try bypass it and earth it out.
I recall a thread on here not too long ago about Sierra clutch switch causing this issue.
Post Posted: Sat Dec 23, 2017 11:47 am
Yeah pete79 had a problem with it. Basically it turns the egr on when the appropriate gear switch is closed. Personally I'd disconnect and block the egr valve. It's on the drivers side of the intake manifold below the carby.
Post Posted: Sat Dec 23, 2017 12:01 pm
Thanks bumstein.....did that and the the problem solved.....
Thankyou all for your valuable feed back,,,merry christmas
Users browsing this forum: No registered users and 54 guests
