It is currently Mon Sep 21, 2026 7:58 am
Vehicle: 1997 Vitara V6
Post Posted: Thu Dec 14, 2017 9:01 am
Hi,
I bought a stock 1997 vitara 2L 5-door and wanted to know if it’s a bad idea to take it to rainbow beach and possibly Fraser Island.
What would be the easiest things to changes to get it more beachworthy? It’s not got huge amounts of ground clearance, can larger tyres be fitted or would other modifications be needed to do that?
Vehicle: 1992 suzuki sierra hardtop
Post Posted: Thu Dec 14, 2017 12:41 pm
Find A good sand worth tire and run the correct psi in them would be my first thing idk to much about sand driving none in my area
Post Posted: Thu Dec 14, 2017 2:57 pm
A taller tyre that’s not too aggressive will help, as will a front skid plate.
These cost money. Letting the tyres down is pretty cheap though.
Post Posted: Thu Dec 14, 2017 3:51 pm
Plain roadies are fine for beach sand. Drop the pressure way down and even the stock size will get you to some surprising places.
225/75x15 fits on stock rims, (IF you can find them)
I found some "Maxtrek" LT tyres at Tyrepower. Not a bad road tyre, and quite ok in sand at 10psi, although it does have a sharpish tread - sidewall edge.
Vehicle: Vitara 1994
Post Posted: Thu Dec 14, 2017 11:43 pm
Go out with a mate, drop the pressures 10-12 psi is a good starting point and go nuts. A 2L vitara is one of the best cars in sand. Just remember momentum is king and try and read the sand ahead so you have time to react.
Vehicle: 1996 Suzuki Vitara SV620
Post Posted: Sat Dec 16, 2017 4:08 pm
I have one and regularly go driving on the sand, tire pressure is key otherwise go out there and have fun. Only issue I ever have is getting stuck in ruts from other bigger cars.
Post Posted: Sun Dec 17, 2017 7:34 am
Cheers for the advice. I’ll let the tyres down and take a shovel/strap etc and see how I go.
Vehicle: G16b sierra
Post Posted: Wed Dec 20, 2017 4:01 pm
Can't go wrong with maxtrax or some other form of recovery track, worth the money I reckon. I unbogged a skyline that took a wrong turn once with them! :lol:
Users browsing this forum: No registered users and 56 guests
