Vehicle: 2011 GV JT Sport
Posted: Sun Dec 31, 2017 6:07 pm
Hey Folks
I’ve a 2011 GV sport that’s having clutch problems. I pressed the pedal the other day and it sank completely to the floor. 20 -30 pumps later it was back up but would fade fast. Fluid in the reservoir had dropped as well but not to the point of empty
So far I have flushed the clutch hydraulics of old filthy fluid, checked for leaks from the master cylinder and piping, replaced the o-ring on the bleeder valve of the slave cylinder external of the bell housing (because I could see small bubbles coming from it while it was locked off).
After all that I flushed and bled the lines and was finally getting clear fluid however the clutch quickly faded again on a test drive. I bled the line again only to have the fluid come out milky and it looked like it had heaps of tiny air bubbles in it.
So before I decide to bleed the lines again, has anyone here got an insight of what may be the cause?
My suspicion - based entirely on the paragraph above - is that you have a defective clutch master cylinder - a leak anywhere else large enough to cause the symptoms you describe will also cause fluid loss and the clutch will not "pump back up" - fluid is leaking internally between the chambers in the master cylinder (it has two sections separated by one of the rubber seals on the piston).
Users browsing this forum: No registered users and 72 guests
