http://auszookers.com/forum/
a very inexperienced newbie
http://auszookers.com/forum/viewtopic.php?f=37&t=54904
Author:  jackyg [ Wed Jan 03, 2018 5:00 pm ]
Post subject:  a very inexperienced newbie
Hi :) my daughter and I are very new to the maintenance and repairs side of things - please be kind - we really want to learn. Firstly, the sierra has a lift kit on it - where do you put the jack i.e. where are the jacking points? TIA :)
Author:  Technotron101 [ Wed Jan 03, 2018 9:36 pm ]
Post subject:  Re: a very inexperienced newbie
Welcome to the forum!
I believe the "correct" position to jack from is under the spring perches (I assume it's a leaf sprung sierra?) if you're using the factory provided scissor jack.
I personally, when using a trolley jack with a concave lifting surface, jack from the diff pumpkin. This usually lifts the whole car off the ground if you keep jacking, otherwise just the wheel closest to the jack will lift (because the diffs are offset to one side).
Hope this helps!
Author:  jackyg [ Thu Jan 04, 2018 9:10 am ]
Many thanks Technotron 101, with a scissor jack, that is what we ended up doing. However, I am thinking that we will just put the wheel back on and try and find someone to fix the fuel pump - its too hard :(
Author:  Gwagensteve [ Thu Jan 04, 2018 9:45 am ]
Hi Jacky.
Technotron is correct - under the spring plate closest to the wheel. This isn't like a road car where the jack goes under the sill or chassis.
It's not a stupid question at all - I've read angry posts from blokes adamant their standard jack is now too small because they have a lift kit.
Author:  just_cruizin [ Thu Jan 04, 2018 9:54 pm ]
Not so good with 35" tyres though
Author:  Technotron101 [ Fri Jan 05, 2018 12:11 am ]
What's up with the fuel pump? Some details would help, and I'm sure some of us here could be of some assistance.
Author:  Gwagensteve [ Fri Jan 05, 2018 7:58 am ]
I have 100x50 RHS welded to the foot of mine and 50x50 SHS welded to the top. Lifts the car with 35’s no problem and still fits under the axle with a 15” rimmed tyre fully deflated.
Of course it no longer fits in the factory spot but that’s the least of your problems running 35’s.
Sounds like your car is running an external in line fuel pump roughly where the stock fuel filter was?
Author:  jackyg [ Wed Jan 10, 2018 1:13 pm ]
Well.... what is wrong with the fuel pump.... I have no idea. It is 17 year old daughter's first car - a 'must have' and 'I'll learn and do all the work'.....
When we test drove the car, it ran well - no issues. Get the car home - doesn't start in the mornings at all - discover 'Start you Bastard' which worked beautifully, but car was still missing around 60k's (not sure of revs). Then, it just conked out - RAC reckoned the fuel pump was broken but maybe a blockage somewhere in the filter, lines... the possibilities are endless...
Mr Rocky and Bumstein have been helpful so far.
