| 16a into sj413 http://auszookers.com/forum/viewtopic.php?f=37&t=54946 |
| Author: | tanked [ Tue Jan 16, 2018 6:12 pm ] |
| Post subject: | 16a into sj413 |
Hello all I am putting a g16a....yes i know its not the ideal motor, the question I have is will i need to do the sump conversion, i have 30mm body lift and 25mm longer shackles and have 30mm extended bumpstops.. I know I could trial fit it when i take the g13 out but i am trying to get the motor as close to bolt in as i can |
| Author: | Kfal [ Tue Jan 23, 2018 1:51 pm ] |
| Post subject: | Re: 16a into sj413 |
If it's a rear wheel drive motor then you shouldn't have to change the sump. Front wheel drive, ideally you would. |
| Author: | tanked [ Tue Jan 23, 2018 7:01 pm ] |
Thanks i was thinking i didnt have to change it but always like a second opinion. Yes it is a rear wheel drive g16a sorry should of said that |
| Author: | claytox [ Thu Jul 05, 2018 9:25 pm ] |
Hey mate, I've done heaps of searching but can't really find any answers. G16A into where a G13A was, basically just get the adapter kit, modify sump (if needed) and you're good to go? is that all? Cheers |
| Author: | Jezzer [ Fri Jul 06, 2018 4:03 am ] |
It will depend if your going to a 8 valve or 16 valve. If your going 8 valve and running your 1300 carb, then it’s pretty straight forward. But if your going for the 16 valve or injection on the 8 valve then there’s more wiring to deal with Sent from my iPhone using Tapatalk |
