Bit of a stretch but does anyone have a m13 jimny and baleno/g13bb engine they could measure the height of for me with a reasonable degree of accuracy from lowest point to highest. Also after different sump configurations available on m series engines including fwd applications. Thinking i might try stuff one in the lj Cheers
Joined: Sat Oct 13, 2012 1:23 pm Posts: 189 Location: VIC
Vehicle: LJ50V 2 stroke
Posted: Wed Mar 14, 2018 8:45 am
the M will fit into an LJ ok, but its friggin tight.It's made a lot easier if you have an 80 hood. I bough a M-Jimny a few months ago for this exact reason, to go into my LJ50. lots of measurements later and its tight as.
the G will fit similarly but you cant use a Vit injection as the cross over pipe will foul the hood. all the others should be ok, but the G is a little taller that the M (possibly 50mm)
Yeah mine is an 80, the remote shifter location and m15/18 upgrade appeals to me. Ive only seen g16 done with body lifts. Sump vs front diff pumpkin is my next concern. Tbh mine isnt for offroad i have a spare diff here id consider chopping the pumpkin flat and only being 2wd for efi and 5spd
Users browsing this forum: No registered users and 60 guests
