It is currently Mon Sep 21, 2026 2:10 pm
Post new topic Reply to topic  [ 44 posts ]  Go to page 1, 2  Next
Vehicle: suzuki sierra 91
Post Posted: Tue Apr 10, 2018 7:44 pm
Been searching and I can’t find the answer or atleast not with the words I’m using so I’m going to have to ask here
So forgive me if it’s been asked before
I have a problem with my 91 g13 stock motor and all I can put it down to is something carby related
The problem is any time the clutch is in and the revs drop to idle it cuts out
Most the time it happens when coming to a stop but it’s also happened when changing gears if the clutch is in to long
The other part of the problem is it’s very random no pattern to it
It will do it for a few days then be good then random start again
Though it was most likely dirty fuel but swapped out the fuel filter and hasn’t seemed to help
Think that’s all if it
Thanks for the help guys
Post Posted: Tue Apr 10, 2018 8:42 pm
Hmmmm.. the stock carby is pretty ordinary now. They’re old and have served their better years long ago.. You can have it professionally rebuilt and it will still have wee issues. I’ve tried it and it’s not a complete solution.
My suggestion is get hold of a corolla 4K carby or a Weber (or FAJS Weber copy) on depending on what suits your use..
Just curious, does it happen with the clutch out, car in neutral and idling away?
Post Posted: Tue Apr 10, 2018 9:02 pm
sometimes it will other times no it will stall
sometimes it will start fine with no throttle other times you have to give her a bit to get it started
Post Posted: Tue Apr 10, 2018 9:16 pm
something like this
https://www.ebay.com.au/itm/Carburetor- ... Sw5cNYPPSi
How hard are there to fit?
Post Posted: Tue Apr 10, 2018 10:26 pm
Yepo much like that one..
I haven’t installed one myself so I’m not the guy to give you the ins and outs, but this should give you the info:
viewtopic.php?f=17&t=16365
My understanding is they’re quite easy to install
Post Posted: Tue Apr 10, 2018 10:46 pm
cheers mate read a bit and I'm going to get one
Post Posted: Wed Apr 11, 2018 9:11 am
Good choice [emoji4] the Weber (of Faj’s) are good for the road but they tend to overfuel on steep inclines. The 4K are cheap and easy and work well by all accounts. Let us know how it goes
Post Posted: Wed Apr 11, 2018 5:15 pm
Anything I can do short of pulling the carby completely apart to get it going untill 4K gets here?
It’s at the point I can’t even driveit to the shops safely as it stalls out 2 or 3 times
Post Posted: Wed Apr 11, 2018 10:19 pm
I’m no carby genius! They’re somewhat a black art as far as I’m concerned..
if you’re at the point where you can’t use it anymore then it seems like a good time to have a random play!!
Perhaps remove the jets and see if they’re blocked. There’s two brass plugs on the side of the float chamber, undo them and you can unscrew the jets with a flathead screw driver.
^this is a blocked jet..
Other than that unleash a can of carby cleaner and see if it helps!! If you start pulling the carby apart you may find small parts spring out and it’s a bastard to find what bits go where (if you can find the bits)
Check for vac leaks in the lines or where the butterfly shafts sit on the throttle body? I’m clutching at straws here
Vehicle: 93 Sierra 2'' lift 30'' tires
Post Posted: Thu Apr 12, 2018 2:04 am
viewtopic.php?f=5&t=54335&start=30#wrapheader
Read that thread by Pete_79. He had a carby issue and it was a simple fix. The answer is on page 2
Post Posted: Thu Apr 12, 2018 11:00 am
I thought about the clutch switch but that problem seems to present as a power issue under load with the clutch out. Ie idles fine, revs fine but in gear with the clutch out it dies in the ass.
Worth a try but doesn’t seem to match the problem that Ratman is describing. He’s saying the problem presents with the clutch in and idling.
Just curious Ratman, you say if the clutch is in too long when changing gear or while idling at lights etc it cuts out (intermittently). If your pulling up and slip it out of gear with the clutch out rather than in does the problem still happen?
Post Posted: Thu Apr 12, 2018 2:03 pm
This. ^
It doesn't seem like Pete's problem but it could still be an EGR issue, with the EGR staying open when it's not meant to or simply the EGR valve not closing fully.
Personally, I'd remove/block all the related vacuum lines/solenoids and block the EGR valve. The whole system is a source of vacuum leaks and running issues. If you're looking at fitting a different carby then you probably aren't very concerned with meeting emissions anyway.
It's easy to remove and plug the vacuum lines that actuate it just to test. You can go one step further and block the ports in the EGR valve to make sure it doesn't leak.
Otherwise you can play with idle speed and mixture. Just turning up the idle a bit might stop it stalling.
Post Posted: Thu Apr 12, 2018 5:51 pm
Yeah still happens
Even atm when you start it got to give it revs then once you drop the revs it cuts out without touching the clutch or gears
About to pull it out and have a look
Post Posted: Thu Apr 12, 2018 6:26 pm
So pulled the hat off the carby and was playing with the throttle and noticed that the butterfly that’s not under the choke side doesn’t move is that normal?
Post Posted: Thu Apr 12, 2018 8:28 pm
That I’m guessing will be the secondary throttle which opens when you go full noise. I think they are vacuum activated rather than linkage so unless the motor is under load it won’t open. Let me check in the morning with one I have at home, however your problem is evident at idle which means both butterfly’s will be fully closed. I wouldn’t think that is your issue
Post Posted: Thu Apr 12, 2018 8:47 pm
Doesn’t look like it’s the jets
Pulled them out and cleaned them still no better so no idea now unless it’s timing but that doesn’t make sense to me
Post Posted: Thu Apr 12, 2018 9:09 pm
The more things you can do like that the more problems you’re ruling out. So check the timing while you’re playing. Checking spark etc is a good idea too..
My money would be on a vac leak somewhere. If not the vac lines, perhaps air getting in somewhere like the butterfly shafts or the like.
Post Posted: Fri Apr 13, 2018 8:14 am
Anybody know what size the vac lines are ?
Plan to get a meter or so and replace all the lines
Post Posted: Fri Apr 13, 2018 9:36 am
8mm vac lines.. and no the secondary butterfly does not open with the throttle linkages, think it’s vacuum operated.
Also check over the Manifold and other areas for anywhere it may be leaking air and/or fuel. My primary butterfly shaft is worn and leaks. I also spent waaaaaaayyyy too much time trying to find a fault where cylinders 1&2 weren’t running properly only to find that a vac port on the Manifold was open.
Again, be aware that you may be chasing a fault that cannot be fixed ie carby is old and rooted. All this is really only to confirm that the carby needs replacing as you already suspect.
Post Posted: Fri Apr 13, 2018 10:56 am
Yeah local mechanic said to spray start you bastard around the carby andsee if the revs show up meaning there’s an air leak
Yeah it is worked that out while I was sitting there playing with it andclezning the jets
Yeah all I’m doing is trying to fix it while I wait for the 4K should be here by Wednesday
Post Posted: Fri Apr 13, 2018 1:22 pm
You’re on the right track then :) you’ll know for sure when you change the carby!!
Post Posted: Fri Apr 13, 2018 3:46 pm
Lol yeah unless it doesn’t fix the issue sad face
Post Posted: Fri Apr 13, 2018 5:14 pm
Well start you bastard didn’t work so any other ideas ?
Post Posted: Fri Apr 13, 2018 5:25 pm
Look forward to seeing the posties happy face on Wednesday
Post Posted: Fri Apr 13, 2018 5:27 pm
Next seimton
Pump the throttle 4-5 times she will start up and idle for maybe 5 seconds before dieing ??
Possible fuel pump failling ? Idk
Post Posted: Fri Apr 13, 2018 5:32 pm
Next seimton
And on another note if I pump the throttle then discount the fuel line it does the same thing as when the fuel is connected
But the fuels still pumping because I put a jug on the line to make sure it was
Post Posted: Fri Apr 13, 2018 8:15 pm
Yeah I’d expect if it were the fuel pump then it would fail under power.. I’m out of ideas unless you feel like cracking that thing open and checking the needle valve and float etc.
Pretty much I don’t think you’ve got a lot to lose between now and Wednesday, pull it apart and see what you can see? Disclaimer here, when you separate the cap from the float/throttle body there’s a spring/ball assy which pings if you’re not careful and it will end up FK where with little chance of knowing where it all came from in which order. I try find a pic which details the where and how
Post Posted: Fri Apr 13, 2018 8:18 pm
Yeah going shopping tomorrow but once I’m home I think I will crack it fully open or burn it to the ground both ideas sound good at this point
Really need to get the gti in my lounge room going so I have efi
Post Posted: Sun Apr 15, 2018 9:32 am
What ever it is I can’t find it so have given up and will wait for the 4K to show
But I did work out how to over come it for now but I wouldn’t requmemd it it’s a very dodgy fix
I ended up adjusting the throttle cable so it will not fully shut and stays open enough to keep her idling at 2grand
Post Posted: Sun Apr 15, 2018 10:03 am
Oh well!! Temporary fix but if it gets you by until Wednesday
Users browsing this forum: No registered users and 37 guests
