It is currently Mon Sep 21, 2026 6:27 am
Vehicle: Grand vitara 2.7 v6 2006
Post Posted: Sun Jun 10, 2018 9:45 am
Hi everyone
I'm new to this site and have recently picked up a 2006 gv 2.7 v6 manual and the geargearbox has a sound like a low range gear whine in 1st and 2nd and I'm not sure if this is normal any help would be appreciated thanks in advance
Rhys
Post Posted: Mon Jun 11, 2018 12:43 am
No it's not normal, start by checking the fluid level - perhaps drain & refill and take a look at what comes out - are there any metal particles in it?
Post Posted: Wed Jun 13, 2018 4:33 pm
Ok thanks for that I will drop the oil and have a check.
If it needs reconditioning would you know anyone around nsw reasonably cheap or any idea how much it would cost.
Thanks in advance not long moved here so not sure where everything is.
Post Posted: Sat Jun 16, 2018 12:19 am
Rebuilding could cost as much as the car is worth. Not sure what you paid for the car, but should have been around the 6K mark.
As fordem says, it is not normal, or common for these boxes to whine, so a s/hand box should be ok & will be a much cheaper option.
Or, just give it heaps in 1st & 2nd :twisted: so you don't spend long in those gears - might shorten it's life if it is a bearing, or last for ages, getting louder if it is a worn gear.
Rgs, Michael.
Users browsing this forum: No registered users and 37 guests
