It is currently Mon Sep 21, 2026 7:56 am
Vehicle: 91 Vitara JX
Post Posted: Thu Jun 28, 2018 4:43 pm
Gearbox in the wife's GV needs a rebuild and have been quoted more than I'm willing to pay as the car has seen better days. I was hoping just to do a gearbox swap but there doesn't seem to be any 2nd hand boxes out there atm.
I have briefly seen comments online about the possibility of the g16b Boxes being the same but after google search and the search function here I can't seem to get an exact answer.
Are they the same, can I get a g16b Gearbox and mate it up to the engine or will there be more to it than that? With the price given for a rebuild I'm looking at just using that cash towards buying her a new model.
Post Posted: Thu Jun 28, 2018 8:29 pm
The question is what are you getting the G16b gearbox from - if it's from an SQ416, it should work, if it's from an SE416, I think it can be made to work, but don't expect it to be a direct swap...
Vehicle: zook
Post Posted: Thu Jun 28, 2018 8:51 pm
Is the GV a 2.0 4cyl or V6?
1.6 and 2.0 are all but the same, with a different 5th gear ratio.
V6 has different bellhousing
Post Posted: Thu Jun 28, 2018 9:24 pm
2.0 4cyl J20a as listed in the title (forgot to put it in the question)...
I haven't got a donor gearbox as yet, my question was made because if it can be swapped them I can try and chase one from a g16b instead of the intended j20a gearbox.
If the SQ416 fits straight up then that might be an option for me to look into.
Vehicle: zook
Post Posted: Thu Jun 28, 2018 9:49 pm
ah yes, there it is...
If you are half way mechanically minded then a gearbox rebuild is not so hard. I've done a couple with no previous experience. Around $300 in parts and supplies. You can buy the bearing kits on ebay from the UK.
https://www.ebay.com.au/itm/Suzuki-Gran ... SwVlVaAwLT
Post Posted: Fri Jun 29, 2018 6:56 am
Don’t j20’s use a hydraulic clutch?
Post Posted: Fri Jun 29, 2018 10:52 am
They do - but so does the G16 if it's from an SQ416.
Post Posted: Fri Jun 29, 2018 11:08 am
Ah right, now I get it. There’s a truly tiny number of SQ416’s in Australia. Miniscule numbers.
Users browsing this forum: No registered users and 54 guests
