It is currently Mon Sep 21, 2026 1:03 pm
Vehicle: 1994 suzuki vitara (efi)
Post Posted: Mon Jul 09, 2018 11:09 am
Hey guys,
Ive got a 94 vitara jlx and i want to get more ground clearance. I had a look over the weekend and i think it already has some sort of after market springs and maybe shocks. Im running 30s already but just want it to sit taller. So my question is, is there any springs and shocks i can put in from another car? Looking at cheaper alternatives to calmini or ome. Cheers guys. This is my lil tig
Post Posted: Mon Jul 09, 2018 12:29 pm
You can jam GV springs in there but it will ride terribly, have no droop and screw the alignment up.
Vehicle: LJ50V 2 stroke
Post Posted: Mon Jul 09, 2018 3:32 pm
looking at that I'd say carry less weight, and start there
Post Posted: Tue Jul 10, 2018 7:36 am
Two inch body lift. 8)
Simple mod, and doesn't mess with alignment and overall suspension operation.
Post Posted: Tue Jul 10, 2018 10:02 am
I don't think a body lift is going to do much for ground clearance ...
Post Posted: Tue Jul 10, 2018 12:58 pm
true ... does get the sills up tho, which is some help, (and bumpers)
Post Posted: Wed Jul 11, 2018 6:54 am
Cheers for the info guys. Another question? Whats involved in putting a manual out of a 97 jx lwb into a 94 jlx swb? Is it a bitch or what?
Post Posted: Wed Jul 11, 2018 8:29 am
Is the 94 manual or auto?
Post Posted: Wed Jul 11, 2018 10:14 am
Auto at thd moment
Post Posted: Wed Jul 11, 2018 10:37 am
Hmm. It’s a messy swap. Doable, but a hassle. You’ll need the pedal box, console, diff gears. From memory the EFI vitaras (97) run a different extension housing on the manual to make the (4speed) auto and manual the same length, whereas the carby 5 speed and 3speed auto is shorter, so you’d have to do a fair bit of messing around.
I might be a bit off, it’s many years since I messed with swapping vitara driveline around, but there’s a fair bit of difference between the efi and carb models.
Obviously there’s also an inhibitor switch you need to eliminate, along with the TV unit on the driver’s strut tower.
I’d never swap an auto car back to manual, so I’m a bit biased, but your car looks pretty standard- why not just find a manual vitara (preferably EFi), or even better, an EFI auto and swap your tyres over?
Post Posted: Wed Jul 11, 2018 1:15 pm
Your gonna hate me but it is an EFI auto! I prefer manuals but will definitely take all your information into consideration thanks heaps dude
Post Posted: Wed Jul 11, 2018 1:18 pm
Long story short im buying a lwb manual 97 jx and ill be swapping over alot of parts and doing a trailer chop. Any ideas or suggestions?
Post Posted: Wed Jul 11, 2018 1:56 pm
The efi auto is sooooo much better than the manual. At everything, but especially off road and compensating for larger tyres.
Post Posted: Wed Jul 11, 2018 2:06 pm
wot ee sedd !
Have had both and IMHO you'd be much better off sticking with the auto EFI. Much more betterer little jigger!
( Currently have a 94 EFI auto LWB )
Post Posted: Wed Jul 11, 2018 2:23 pm
So Yu currently have a carby or efi auto SWB?
Post Posted: Wed Jul 11, 2018 5:04 pm
Efi swb 94. im hearing that more and more you might have just changed my mind. I need to get the tps or throttle body replaced because its not running right and i think thats the main reason for wanting to go to manual (feel ill have more power)
Post Posted: Sat Jul 14, 2018 11:14 am
That's a different issue. What's the symptoms?
Users browsing this forum: No registered users and 58 guests
