| how to remove the pilot/spigot clutch bearing http://auszookers.com/forum/viewtopic.php?f=37&t=55318 |
| Author: | Aircobra101 [ Thu Jul 19, 2018 8:10 pm ] |
| Post subject: | how to remove the pilot/spigot clutch bearing |
my one is stuck solid. i think someone stuck the shaft into so hard, it jammed the cage i've tried jamming it with a screwdriver, but i can;t get an edge on it and i dont want to scratch the surface the issues is that the standard chinese/repco 3 jaw pullers have a 13mm min diameter and the hole is 10mm exactly any ideas? |
| Author: | Aircobra101 [ Thu Jul 19, 2018 8:13 pm ] |
| Post subject: | Re: how to remove the pilot/spigot clutch bearing |
even this one is 11mm |
| Author: | Aircobra101 [ Thu Jul 19, 2018 8:22 pm ] |
i mean this one https://www.ebay.com.au/itm/5-pc-Inner- ... =R40&rt=nc |
| Author: | bumstein [ Thu Jul 19, 2018 9:45 pm ] |
I’ve seen someone remove a stuck fast one using hydraulic pressure. They filled the hole with as much grease as possible, found a round rod to fit as snug as possible (but not tight) in the hole and tapped the rod firmly with a hammer. The resulting increase of pressure behind the bearing pushed the bearing outwards |
| Author: | Gwagensteve [ Thu Jul 19, 2018 10:04 pm ] |
Bread/grease/hand cleaner/ anything thick and a pin punch the right diameter. |
| Author: | losfer [ Fri Jul 20, 2018 10:44 pm ] |
Im a mechanic and an engineer and steve is sort of on the money but not quite there. Grease etc is still too viscous and can never really reach a "solid" state. So i use................... Paper. Soak paper in water keep punching it in with drift the size of bearing id. Water pushes out paper becomes solid and pushes bearing out. |
| Author: | fordem [ Sat Jul 21, 2018 7:34 am ] |
Why does it need to reach a "solid" state - does the hydraulic fluid in a 12 ton press ever reach a solid state? |
| Author: | HarryHoudini [ Sat Jul 21, 2018 9:36 am ] |
I haven't done one for years but the Ford ones in the 4 Cylinder Motors, (Escort,Cortina etc) ,often use to seize in and we used those masonry bolts that tighten and expand,small dent type slide hammer behind a washer and end nut and they use to pop out easily. |
| Author: | Gwagensteve [ Sat Jul 21, 2018 11:02 am ] |
https://youtu.be/2TBZH5R4Cno Bread also works but i'd assume bread will be in your tummy and grease will be lying around the workshop. |
| Author: | Aircobra101 [ Sat Jul 21, 2018 7:39 pm ] |
harry's idea looks like the winner to me. why didn't i think if that? |
| Author: | Gwagensteve [ Sat Jul 21, 2018 7:47 pm ] |
Seems harder than a bit of grease to me. |
| Author: | bumstein [ Sat Jul 21, 2018 9:15 pm ] |
All good ideas fellas!! Will tuck those away in the memory banks for a frustrating day |
| Author: | VitNick [ Sun Jul 22, 2018 5:14 pm ] |
In my LJ the needle roller just pulled to pieces with the puller after the grease trick and others didn't work. Just got a tiny 2mm carbide burr ($30 at bunnings) and cut a slot in the outer race until it came loose. Worked a treat but I'd only keep it as a backup plan |
